2012 International 7400 Altec Crane Truck with Digger Derrick – Tandem Axle
Posted Date: Jul 9th, 2025 at 05:26 AM
Price: $63830.00
🚧 2012 International 7400 Altec Crane Truck with Digger Derrick – Tandem Axle
Powerful Pole Setter | Built for Utility, Construction, and Line Work
🛠️ Truck Specs – 2012 International 7400
  • Engine: MaxxForce DT Diesel – 300–330 HP range (depending on spec)
  • Transmission: Allison 3000 RDS Automatic – Rugged, reliable, and operator-friendly
  • Mileage: Approx. [insert actual miles] – Fleet maintained with service records available
  • GVWR: 54,000 lbs (Tandem axle) – Built for heavy lifting and hauling
  • Axles: Tandem rear axle for greater stability and weight distribution
  • Cab:
    • Standard day cab
    • Cruise control, PTO switch, air brakes
    • Clean interior with durable vinyl seats and flooring
  • Condition: Turnkey unit – clean title, ready to hit the field
🏗️ Altec Digger Derrick Crane System
  • Model: Altec D3060, D845, or similar (confirm actual model on unit)
  • Max Lifting Capacity: 25,000 – 30,000 lbs (depending on model & boom configuration)
  • Sheave Height / Reach: Approx. 40–60 ft (standard boom) – ideal for setting utility poles or lifting transformers
  • Boom Type: Telescopic hydraulic boom with winch and auger attachment
  • Crane Rotation: 360° continuous rotation with hydraulic swing
  • Controls:
    • Ground & upper seat controls for versatility
    • Dual-function levers or joystick (model-specific)
  • Outriggers:
    • Hydraulic A-frame or radial outriggers for jobsite stability
    • Fully operational and leak-free
🔩 Digger Derrick & Pole Work Setup
  • Auger Included: Heavy-duty auger with flighting – drills through dirt, clay, or rocky terrain
  • Pole Clamps / Guides: Optional utility attachments for pole handling
  • Winch Line: Strong lifting cable with hook block, ready for rigging
  • PTO System: Hot-shift PTO to power hydraulic systems directly from truck engine
⚙️ Utility Body & Rear Setup
  • Body Type: Utility/digger body with material handler setup
  • Storage Compartments: Multiple lockable side boxes for tools, chains, rigging gear
  • Rear Work Platform: Non-slip surface with step access
  • Lighting: DOT lighting, work lights, and beacon/strobe included
✅ Applications
  • Electrical utility contractors
  • Power pole setting and removal
  • Telecom line installation
  • Construction, oilfield, and infrastructure development
  • Municipal or co-op fleet operations
🔍 Condition & Extras
  • Year: 2012
  • Mileage / Hours: [Insert actuals here]
  • Tires: 70%+ tread all around
  • Brakes & Suspension: Inspected and DOT compliant
  • Clean Title: No accidents or salvage history
  • Service: Fresh oil, filters, hydraulic check – jobsite ready
💰 Pricing, Delivery & Financing
  • Priced to move – competitive vs. market for 8x6 crane/digger units
  • Financing available (OAC)
  • Nationwide delivery arranged – fast turnaround
  • Trade-ins welcome – ask about package fleet deals
🔧 Why This Truck?
  • Pre-DEF, Tier 4 Simplicity – No DPF or DEF system headaches (MaxxForce DT)
  • Built by Altec – #1 in utility cranes and diggers
  • Rugged tandem axle ensures heavy lifting without compromising balance
  • Perfect for pole work, heavy lifting, line maintenance, and contractor fleets
  • Ready for municipal bids, rental use, or expansion of private fleets
