2023 OKADA OKADA FACTORY SHOP REBUILT 7500 FT LB 250 - 450 CLASS EXCAVATOR HAMMER / CONCRETE - ROCK BREAKER
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16 Thumb 17 Thumb 18
Price: $45000.00
 OKADA ORV7500 — Mid-Class Hydraulic Breaker
✅ Factory Shop Rebuilt — 6-Month Okada Factory Warranty
📍 Location: Langley, BC (Ships directly from our yard)
💵 Price: $45,000.00 CAD
(New replacement cost: $105,000.00 from Okada)
🔹 Key Features & Details:
  • 2020 Model — purchased new in 2020, now considered a 2023 unit after full Stage 2 rebuild.
  • Factory Rebuild — performed at Okada’s Oregon facility.
    • Rebuild cost: $27,000.00 USD / $37,000.00 CAD.
  • Rebuild Includes:
    • All new bushings.
    • New seal kit.
    • New pistons.
    • 1 brand new and 1 slightly used original Okada Moil Point (total of 2 tools).
    • Complete reseal at Okada Factory Repair Shop.
    • New nitrogen charge for optimal power and performance.
✅ Ready to Work — Low-hour hammer used for only one project prior to COVID. ✅ Factory Tested & Certified Rebuild — Warranty included. ✅ Invoice Available (See image #3). ✅ Fast Shipping — Shipped on our account with competitive freight rates.
🔹 Why Choose the Okada ORV7500?
  • Auto-Lube System — Easily adaptable to automatic lubrication systems.
  • Main Valve — Internal control valve boosts impact energy while reducing heat.
  • Large Capacity Accumulator — Reduces shock load on your carrier machine.
  • Stroke Adjuster — Variable speed control for optimized productivity.
  • Original Holding System — Powercell placement reduces recoil and improves durability.
  • Larger Nitrogen Gas Chamber — Maintains high-impact force.
  • Long Stroke Piston — Reduces vibration while increasing striking power.
  • Dual Chisel Retaining Pins — Extends service life of the tool.
  • Durable Breaker Bracket — Heavy-duty bottom plate reduces noise and vibration.
🔹 Technical Specifications:
  • Impact Energy Class: 7500 ft-lb / 10,170 Joules
  • Operating Weight: 5,950 lbs / 2,698 kg
  • Oil Flow: 63-72 GPM / 238-272 LPM
  • Frequency:
    • L-Mode: 230–400 BPM
    • S-Mode: 270–470 BPM
  • Operating Pressure: 2,320–2,600 PSI / 157–180 bar
  • Mechanical Energy:
    • 98–133 HP / 73.4–99.5 kW
    • Average: 115.5 HP / 86 kW
  • Unit Working Length: 124 in / 315 cm
  • Tool Diameter: 6.1 in / 155 mm
  • Tool Working Length: 30.2 in / 767 mm
  • Noise Level: 85 dB(A) at 119–167 ft / 36–51 m
  • Carrier Weight Range: 60–92 lbs / 27–42 metric tons
🎁 Bonus Deal:
  • $80K New Old Stock Okada Demolition Processor
    (Fits 200–350 Class Machines)
    • 🔥 Available for $25,000.00 CAD!
    • (Check our other ads for full details)
📞 Contact:
Frank — Call/Text/WhatsApp: 604-476-7777
