2025 New Talaria Sting R MX5 Pro 13000W 45 Max Climbing Angle Off Road Electric Motorcycle Dirt Bike
Posted Date: Nov 28th, 2025 at 11:10 AM
Price: $1500.00
Key specifications
  • Motor and power:
    • 13,000W peak power
    • 72V nominal voltage
    • Torque: 250Nm (max output) or 500N.m (unrestricted, with 428 48T sprocket)
    • Power modes: Eco, Sport, and Hyper
  • Battery:
    • 72V 40Ah Li-ion battery
    • Samsung 50S cells
    • Range: Over 60 km (37 miles) on a single charge
  • Performance:
    • Max Climbing Angle: 45°
    • Max Speed: Factory limited to 32 km/h (20 mph)
    • Max Recommended Load: 100 kg (220 lbs)
  • Brakes and suspension:
    • Brakes: Hydraulic 4-piston disc brakes
    • Brake Disc: 220mm x 3mm
    • Front Suspension: Adjustable Hi-Performance Dual Spring Fork with 200mm+2 travel
    • Rear Suspension: Adjustable 85mm+2 travel diameter reducing spring shock absorber with linkage
  • Tires and wheels:
    • Tires: CST Brand, FR: 70/100-19, RR: 80/100-19
  • Dimensions and weight:
    • Dimensions: 1880 x 770 x 1088mm
    • Seat Height: 840mm
    • Net Weight: 76 kg (159 lbs) with battery
  • Electronics and display:
    • Display: Color TFT that shows speed, battery level, voltage, and odometer
    • Connectivity: Bluetooth, electronic, digital, and voice control options
    • Regenerative Braking: 4-level adjustment
Top Speed (km/h) 32
Brakes Front / Rear Disc
Seating Capacity 1
Condition Excellent - As New
Doors 1
Transmission Automatic
