Broderson 8-Ton Rough Terrain Crane
Posted Date: Jul 8th, 2025 at 10:24 PM
Price: $17000.00
πŸ—οΈ Broderson 8-Ton Rough Terrain Crane
Compact. Capable. Built for the Toughest Jobsites.
πŸ”§ Crane Specifications – Broderson RT-300 or IC-80 Series (8-Ton Class)
(Note: Confirm exact model: IC-80, RT-300, or other 8-ton Broderson unit)
  • Capacity: 16,000 lbs (8 U.S. tons) – Ideal for utility work, plant maintenance, and light construction
  • Boom Type: 3- or 4-section hydraulic boom – Smooth, strong, and reliable for precise material placement
  • Boom Reach:
    • Main boom: Approx. 30–50 ft (model-dependent)
    • Optional Jib Extension: Adds 10–15 ft additional reach for vertical lifts
  • Hook Block & Ball Included – Single or 2-part line block (based on configuration)
  • Controls:
    • Dual-lever or joystick hydraulic control system
    • Smooth feathering and proportional lifting
  • Rotation: 360Β° continuous rotation with hydraulic swing motor
  • Outriggers: Hydraulic outriggers with independently controlled legs for uneven terrain stability
πŸ› οΈ Engine & Drive
  • Engine Type: Diesel or dual-fuel (Gas/LPG) depending on model – Tier 3 or Tier 4 final
  • Transmission: Powershift or hydrostatic, 2WD or 4WD rough terrain axle configuration
  • Steering:
    • 4-Wheel Steering
    • 2-Wheel Steering
    • Crab Steering modes
  • Max Travel Speed: 15–20 mph (ideal for large industrial yards or construction zones)
  • Gradeability: Handles slopes and uneven jobsite terrain with ease
🧰 Key Features
  • Compact footprint – Fits where larger cranes can’t (ideal for tight spaces, plants, refineries)
  • Pick-and-Carry Capability – Move loads while carrying them, reducing setup time
  • Easy transport – Lightweight enough for tag trailer or tilt-deck hauling
  • Operator Cabin:
    • Enclosed or open cab
    • Simple control layout
    • Safety glass, adjustable seat, and roof window for boom visibility
  • Safety Systems:
    • Load Moment Indicator (LMI)
    • Anti-two-block warning
    • Outrigger interlocks and boom angle limiters
πŸ” Perfect For:
  • Steel erection
  • Plant maintenance
  • HVAC unit placement
  • Oil & gas field work
  • Mining & utility yards
  • Construction sites with access limitations
πŸ“¦ Condition & Availability
  • Year: [Insert year]
  • Hours: Low hours, work-ready condition
  • Inspection: Fully inspected, greased, and ready for jobsite use
  • Title: Clean title, service records available
  • Located in: [Insert city/state]
  • Delivery: Nationwide shipping available
πŸ’΅ Financing & Options
  • Competitive pricing – Save big vs. brand-new units
  • Financing available (OAC)
  • Buy, lease, or rent-to-own options available
  • Package deals available for multi-unit purchases or fleet upgrades
πŸ”§ Why Broderson?
  • Industry-leading compact crane manufacturer
  • Trusted by refineries, contractors, and rental fleets for decades
  • Simple to operate, easy to maintain, and highly durable
  • Excellent resale value and low total cost of ownership
