ESCO EXTREME DUTY 32 AND 48 INCH DIGGING BUCKETS FIT KOMATSU PC 308 KOMATSU PC 200 KOMATSU PC 238 OR ANY 200 TO 300-CLASS EXCAVATOR
Price: $8000.00
CLASS EXCAVATOR C/W 13 INCHES BETWEEN THE EARS AND 80MM PINS - ALSO WORKS ON ANY KOMATSU PC 200 - 308 EXCAVATORS WHICH HAS 12.75 INCHES BETWEEN THE EARS FOR THE STICK
ESCO EXTREME-DUTY PC200-308 KOMASTSU 32" - 50" BUCKETS PERFECT
ESCO EXTREME DUTY DOUBLE BOTTOM PC308 KOMATSU SERVICES - PIPELINE - ROCK BUCKETS
ESCO CUSTOM-BUILT FULL 2 YARD BUCKET THAT IS 50 INCHES WIDE OUTSIDE - WITH 5 EXTREME DUTY TIGER TEETH
ALSO, HAVE AN AS NEW CP 24 EXTREME RIPPER BUCKET WITH OFFSET LONG RIPPER SHANKS DUTY BUCKET THAT IS SET UP WITH THE 80 MM PINS - TAKE IT FOR $8000.00
OR TAKE BOTH BUCKETS FOR $15,000.00
THE BUCKETS ARE ALL AS NEW WITH MANY HOURS OF HARD SURFACE WELDING DONE ON ALL WEAR SURFACES AND SET OF EXTREME DUTY SIDE CUTTERS
BUCKET IS DESIGNED TO GIVE EXTREME DUTY WORK WITH HIGH CAPACITY FOR LOADING TRUCKS - DIGGING SHALE - SANDSTONE - EXTREME DUTY DEMOLITION ETC
THE BUCKET HAS 80 MM PINS ON 20-INCH CENTERS AND 13.10 INCHES BETWEEN THE EARS AND INCLUDES THE CASE HARDENED PINS
TKomatsu PC 308
Komatsu PC 200
Komatsu PC 238
ANY 200 TO 300-CLASS EXCAVATOR THAT HAS A PIN GRABBER FOR 80 OR 90 MM PINS WITH LESS THAN 13 INCHES ACROSS THE BOTTOM OF THE QUICK COUPLER
THE BUCKET HAS BEEN FACTORY REINFORCED WITH ADDITIONAL DOUBLE BOTTOM T-1 PLATE STEEL ACROSS THE BOTTOM AND DAYS OF HRD SURFACING DONE AND NEW TEETH AND IS READY TO WORK
THIS BUCKET NEW FROM ESCO IS OVER $20,000.00 AND 16 WEEKS LEAD TIME
TAKE IT FOR $8000.00 OR TAKE BOTH ESCO BUCKETS FOR $15,000.00
THIS BUCKET WILL PAY FOR ITSELF ON THE FIRST HARD DIGGING JOB ON TIME SAVED LOADING TRUCKS WITH ITS LARGE 2-YARD VOLUME
BOTH BUCKETS AMERICAN BUILT FROM QUALITY ESCO FOUNDRY T-1 OR BETTER STEEL - NO CHINESE JUNK HERE LIKE RITCHIE'S BROS SELL
FROM THE ESCO WEBSITE:
Extreme-Duty Excavator Bucket (XDP)
The XDP bucket is engineered for tough overburden digging applications.
The XDP bucket provides superior performance when top-loading or excavating rock material.
The XDP features:
Lip and beam gussets that provide increased durability in high-stress corners.
T1 steel one-piece reinforcing plates for additional side plate strength and wear resistance.
400 Brinell bottom runner wraps under the lugs for full abrasion resistance and additional structural integrity.SERVICES - PIPELINE BUCKET
ESCO CUSTOM-BUILT BUCKET THAT IS 32 INCHES WIDE OUTSIDE ON THE EXTREME DUTY SIDE CUTTERS ABD 30 INCHES ACROSS WITHOUT SIDE CUTTERS - WITH 4 ESCO HD TEETH
HAS MANY HOURS OF HARD SURFACE WELDING DONE ON ALL WEAR SURFACES AND SET OR EXTREME DUTY SIDE CUTTERS
THE BUCKET HAS 80 MM PINS ON 20-INCH CENTERS AND 13.10 INCHES BETWEEN THE EARS AND INCLUDES THE CASE-HARDENED PINS
Komatsu PC 308
Komatsu PC 200
Komatsu PC 238
ANY 200 TO 300 CLASS EXCAVATOR THAT HAS A PIN GRABBER WITH LESS THAN 13 INCHES ACROSS THE BOTTOM OF THE COUPLER
THE BUCKET HAS BEEN FACTORY REINFORCED WITH A FULL ADDITIONAL T-1 PLATE DOUBLE BOTTOM AND ADDITIONAL WEAR BOTTOM BARS AND DAYS OF HARD SURFACING DONE AND NEW TEETH AND IS READY TO WORK
THIS BUCKET NEW FROM ESCO IS OVER $15,000.00
TAKE IT FOR $8000.00 OR OR TAKE BOTH BUCKETS FOR $15,000.00
THIS BUCKET WILL PAY FOR ITSELF ON THE FIRST SHORING TRENCHING JOB ON TIME
BUCKETS ARE AT OUR YARD LANGLEY BC - WE GET GREAT FAST SHIPPING AT EXTREMELY GOOD RATES DELIVERED TO YOUR DOOR
FRANK 604-476-7777 OR TOLL FREE Phone : 1-(833) 693-9323
