ESCO EXTREME DUTY 350-500 EXCAVATOR RIPPING- TRENCHING SHORING
Posted Date: Oct 21st, 2023 at 09:35 AM
Price: $8000.00
BUCKET WITH CAGE, PIPELINE, EXTREME DUTY SHALE, SANDSTONE RIPS, BUT HIGH VOLUME, TRUCK LOADING
ESCO PERSONALIZED DROP CENTER BUCKET WITH A 28-INCH WIDE 3-TOOTH CENTER SECTION AND AN OUTSIDE WIDTH OF 48 INCH
According to worksafe regulations, the bucket's design allows for extreme ripping over the drop center section and allows for the placement of shelving brackets over the 36-inch higher uppercut edge. This frequently eliminates the need for two shelving brackets in deeper trenches or permits the use of shorter shelves in shallower trenches.
OR FOR SHALE: HIGH CAPACITY RIPSTING SANDSTONE FIT FOR LOADING TRUCKS
The bucket measures 85 inches from the stick pin center to the tip of the three tooth ripper section, adding 13 inches to the digging depth compared to standard buckets.
OUR EC480DL VOLVO HAD PIN GRABBER, BUT THIS BUCKET HAS 100 MM PINS ON 23 INCH CENTERS AND 17 INCHES BETWEEN THE EARS, BUT IT WILL WORK ON ANY MACHINE THAT ACCEPTS THOSE PINS SIZES.
(NOTE: PLEASE NOTE THAT I HAVE ADDITIONAL ADS FOR DROMONE HYDRAULIC PIN GRABBER COUPLERS FOR THIS BUCKET, AS WELL AS A PERFECT HD 48 INCH DIGGING BUCKET FOR $12000.00 AND A 24 INCH ESCO RIPPING BUCKET WITH NEW 100 MM PINS INSTALLED FOR $4000.00 - ALSO A 350 - 400 JD / HITACHI DROMONE HYDRAULIC QUICK COUPLER THAT FITS THIS BUCKET FOR $6000.00),
After receiving additional T-1 plate steel reinforcement, hard surfacing, and new teeth, the bucket is now prepared for cage work or extreme duty ripping.
THIS NEW ESCO BUCKET IS WORTH MORE THAN $25,000.00 USD.
BUY IT FOR $8000.
With its large volume, this bucket will pay for itself on the first job—shoring, trenching, loading trucks—while saving time and requiring less bedding material.
LOCATED OUR YARD LANGLEY BC
I just reduced the price to get this moved quickly.
RETIRING BACK TO OUR NEW HOME IN NB DUE TO HEALTH ISSUES FROM THE FOREST FIRE SMOKE PARTICULATES AND EXTREME TRAFFIC AND ITS SMOG IN THE FRASER VALLEY AND CLEARING OUT MY YARD TOTALLY, PLEASE VIEW MY OTHER EXCAVATING AND DEMOLITION EQUIPMENT FOR SALE.
604-476-7777 FRANK
FROM THE WEBSITE OF ESCO:
Heavy-Duty Excavator Pail (XDP)
The XDP bucket is designed to handle demanding overburden excavation tasks.
When top-loading or excavating rock material, the XDP bucket performs better.
The XDP features:
Lip and beam gussets that provide increased durability in high stress corners. T1 steel one-piece reinforcing plates for additional side plate strength and wear resistance. 400 Brinell bottom runner wraps under the lugs for full abrasion resistance and additional structural integrity
