ESCO EXTREME DUTY 350-500 EXCAVATOR RIPPING- TRENCHING SHORING
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12
Price: $8000.00
CAGE BUCKET - PIPELINE BUCKET - EXTREME DUTY SHALE - SANDSTONE RIPPING YET HIGH VOLUME TRUCK LOADING BUCKET
ESCO CUSTOM BUILT DROP CENTER BUCKET THAT IS 48 INCHES WIDE OUTSIDE - WITH 28 INCH WIDE 3 TOOTH CENTER SECTION
BUCKET IS DESIGNED TO GIVE EXTREME RIPPING OVER DROP CENTER SECTION AND ALLOW FOR SHORING CAGES TO SIT OVER THE 36 INCH HIGHER UPPERCUT LEDGE - AS PER WORKSAFE REGULATIONS - OFTEN ELIMINATING TWO STACKING SHORING CAGES IN DEEPER TRENCHES OR ALLOWS USING SHORTER CAGES IN SHALLOWER TRENCHES
OR FOR SHALE - SANDSTONE RIPPING WITH HIGH CAPACITY FOR LOADING TRUCKS
BUCKET IS 85 INCHES FROM CENTER OF STICK PIN TO TIP OF 3 TOOTH RIPPER SECTION GIVING AN ADDITIONAL 13 INCHES OF DIGGING DEPTH OVER STANDARD BUCKETS
BUCKET HAS 100 MM PINS ON 23 INCH CENTERS AND 17 INCHES BETWEEN THE EARS WE USED ON OUR EC480DL VOLVO WITH PIN GRABBER BUT WILL WORK ON ANY MACHINE THAT ACCEPTS THOSE PINS SIZES
( NOTE: SEE MY OTHER ADS FOR DROMONE HYDRAULIC PIN GRABBER COUPLERS FOR THIS BUCKET ALONG WITH A PERFECT HD 48 INCH DIGGING BUCKET FOR $12000.00 AND ALSO A 24 INCH ESCO RIPPING BUCKET WITH NEW 100 MM PINS INSTALLED FOR $4000.00 - ALSO A 350 -400 JD / HITACHI DROMONE HYDRAULIC QUICK COUPLER THAT FITS THIS BUCKET FOR $6000.00)
BUCKET HAS BEEN REINFORCED WITH ADDITIONAL T-1 PLATE STEEL AND DAYS OF HARD SURFACING DONE AND NEW TEETH AND IS READY FOR CAGE WORK OR EXTREME DUTY RIPPING
THIS BUCKET NEW FROM ESCO IS OVER $25,000.00 USD
TAKE IT FOR $8000.00
THIS BUCKET WILL PAY FOR ITSELF ON THE FIRST SHORING TRENCHING JOB ON TIME SAVED AND LESS BEDDING MATERIAL USED OR SANDSTONE - SHALE RIPPING JOB LOADING TRUCKS WITH ITS LARGE VOLUME
LOCATED OUR YARD LANGLEY BC
JUST LOWERED THE PRICE TO TO MOVE THIS QUICKLY
SEE MY OTHER EXCAVATING AND DEMOLITION EQUIPMENT FOR SALE AS RETIRING BACK TO OUR NEW HOME IN NB DUE TO HEALTH ISSUES FROM THE FOREST FIRE SMOKE PARTICULATES AND EXTREME TRAFFIC AND ITS SMOG IN THE FRASER VALLEY AND CLEARING OUT MY YARD TOTALLY
FROM THE ESCO WEBSITE:
Extreme-Duty Excavator Bucket (XDP)
The XDP bucket is engineered for tough overburden digging applications. The XDP bucket provides superior performance when top-loading or excavating rock material.
The XDP features:
Lip and beam gussets that provide increased durability in high stress corners. T1 steel one-piece reinforcing plates for additional side plate strength and wear resistance. 400 Brinell bottom runner wraps under the lugs for full abrasion resistance and additional structural integrity
