Fleco 250-350 CLASS HEAVY DUTY 24 INCH TRENCHING BUCKET CAT 329 EXCAVATOR BUCKET CB LINKAGE 90 MM PIN BORES
Posted Date: Oct 28th, 2023 at 04:52 AM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11
Price: $6000.00
FITS ANY 240-350 EXCAVATOR WITH HYDRAULIC PIN GRABBER COUPLER
CAT 329E - WITH BC LINKAGE 24 INCH HD TRENCHING BUCKET WITH  TRECHING FLAT BOOT WEAR PLATE  VIN  # 44224
FLECO Heavy-Duty Excavator Buckets are designed for digging in a broad range of materials including dirt and clay.
 FLECO uses AR400 Steel on the Side Wear Plates, Cutting Edges, Mounting Brackets and reinforcing Wear Bars.
 AR400 is much stronger and wear resistant than T1 Structural Steel. FLECO Bucket Shells are rolled and constructed from A-572-50 Steel.
Designed with Heavy-Duty AR400 Steel
All Excavator Buckets are built to OEM Specifications
Equipped with Thick Wear Straps and Wear Pads
Included with Standard J-Series Style Teeth
Included with D-Ring
Optional Side Cutters (12K lbs. Class & Up)
Optional Dead Pins
90 mm Stick Pin Diameter, 90 mm Link Pin Diameter, 495 mm Center of Pin Boss to Center of Pin Boss, 390 mm Inside to Inside Pin Boss Spacing
Fleco Attachments is a leading manufacturer and supplier of high-quality excavator attachments for a variety of industries.
 With years of experience in the field of heavy equipment, we have developed a reputation for producing durable, reliable, and efficient attachments that help our customers get the job done.
Our team of engineers and technicians is dedicated to developing innovative solutions that meet the evolving needs of our customers.
 We understand that each project is unique, and we work closely with our clients to create customized attachments that are designed to meet their specific requirements.
At Fleco Attachments, we take pride in our commitment to quality.
Every attachment we produce is built to the highest standards, using the best materials and manufacturing techniques available.
 We also place a strong emphasis on safety, and all of our products are rigorously tested to ensure that they meet or exceed industry safety standards.
Whether you need a hydraulic thumb, a bucket, or a custom attachment designed specifically for your application, Fleco Attachments has the expertise and experience to deliver the solutions you need.
 Contact us today to learn more about how we can help you achieve your goals.
~ Fleco Team
BUILT FOR MANUFACTURERS
CAT, CASE, KOBELCO, SANY, JOHN DEERE, HITACHI, KOMATSU, TAKEUCHI, KUBOTA, LINK BELT, VOLVO, HYUNDAI, LUI GONG, NEW HOLLAND, DOOSAN, JCB, SAMSUNG, DAEWOO, KAWASAKI, YANMAR, BOBCAT
