Hydra-Lift Crane โ Rugged, Simple, and Built for Work
Posted Date: Jul 8th, 2025 at 10:38 PM
Price: $75000.00
๐๏ธ Hydra-Lift Crane โ Rugged, Simple, and Built for Work
Reliable Hydraulic Lifting | Field-Tested Strength | Ideal for Utility, Construction & Material Handling
๐๏ธ Crane Overview โ Hydra Lift Hydraulic Crane
(Note: Hydra-Lift offers several models. Customize specs below based on your specific unit โ 5000 lb, 8000 lb, 10,000 lb, etc.)
Make/Model: Hydra-Lift [Insert specific model, e.g., 8000 or 10K series]
Lifting Capacity:
Approx. 5,000 โ 10,000 lbs (model-dependent)
Designed for safe, consistent hydraulic lifts across varied jobsites
Boom Type:
Telescopic or articulating (confirm configuration)
Steel-reinforced hydraulic boom sections
Reach:
Horizontal: Up to 20โ30 ft
Vertical: Approx. 25โ35 ft lifting height
Mount Type:
Truck-bed mounted, skid-mount, or standalone โ versatile install options
Rotation: 360ยฐ continuous or 180ยฐ mechanical swing (model-specific)
Winch System: Heavy-duty cable winch with durable hook block
Power Source: PTO hydraulic (truck-mounted) or self-contained hydraulic pump
๐ฎ Controls & Functionality
Operator Controls:
Side-mounted levers or optional pendant remote
Easy-to-operate with precision feathering for safe placement
Safety Features:
Load-limiting valves
Hydraulic bypass protection
Emergency shut-off (if applicable)
Stability:
Manual or hydraulic outriggers for ground support
Locking pins and stabilizer pads for balanced lifting
๐ Compatible with These Platforms
Service trucks (Ford F550โF750, Freightliner M2, International 4300/7400)
Flatbeds, mechanic bodies, utility trucks
Agricultural trailers, tow trucks, and construction platforms
โ Applications
Equipment loading/unloading
Generator or tank placement
Roofing and construction supply delivery
Utility pole handling
Agricultural and oilfield equipment lifts
Tree service or landscaping material delivery
Welding, fabrication, or mobile mechanic operations
๐ Condition & Details (for Used Units)
Year: [Insert manufacture year]
Condition: Fully operational โ tested and serviced
Mounting Base: Clean welds, reinforced subframe
Hydraulics: Leak-free cylinders, pressure-tested lines
Title/Docs: Clean title or serial number tag intact
๐ฐ Pricing & Delivery
Great value compared to new cranes from Venturo, IMT, Stellar, or Auto Crane
Financing and install options available (OAC)
Mounting & PTO setup services offered
Nationwide delivery or crating for shipping
๐ง Why Choose Hydra Lift?
Trusted for decades in oilfields, utilities, and agricultural sectors
Mechanically simple + hydraulically powerful = low maintenance cost
Easily mounted, controlled, and serviced
Excellent for contractors, small fleets, and field teams needing reliable lifting without high cost
