KOMATSU PC400-PC490 ESCO EXTREME DUTY 32 -50 INCH DIGGING BUCKET
Posted Date: Oct 20th, 2023 at 06:29 AM
Price: $8000.00
WORKS ON ANY KOMATSU PC 400 - 47908 EXCAVATOR THAT HAS 16 INCHES BETWEEN THE EARS FOR THE STICK. CLASS EXCAVATOR C/W 16 INCHES BETWEEN THE EARS AND NEW 100MM PINS
Perfect extreme duty bucket, ESCO EXTREME-DUTY PC200-308 KOMASTSU 32"
ROCK BUCKETS - PIPELINE - ESCO EXTREME DUTY DOUBLE BOTTOM PC308 KOMATSU SERVICES
I also have a brand-new, as-of-use CP 24 Extreme Ripper bucket with an off-set long, shank-duty bucket that is assembled with 80 mm pins; it is available for purchase for $8000.00.
OR PAY $15,000 FOR BOTH BUCKETS.
With a set of extremely durable side cutters and hours of labor-intensive surface welding on all wear surfaces, the buckets are all as good as new.
BUCKET IS MADE TO PROVIDE HIGH CAPACITY EXTREME DUTY WORK FOR SANDSTONE, DIGGING SHALE, LOADING TRUCKS, EXTREME DUTY DEMOLITION, ETC.
The bucket includes the case hardened pins and has 80 mm pins on 20-inch centers and 13.10 inches between the ears.
THIS BUCKET FITS THE FOLLOWING MACHINES :
Komatsu PC 308 Komatsu PC 200 Komatsu PC 238
ANY 350 TO 500 -LASS EXCAVATOR THAT HAS A PIN GRABBER FOR 100 MM PINS WITH LESS THAN 16 INCHES ACROSS THE BOTTOM OF THE QUICK COUPLER
After days of hard surfacing, additional double bottom T-1 plate steel across the bottom, and new teeth, the bucket has been factory reinforced and is now ready to operate.
This new ESCO bucket has a lead time of 16 weeks and costs more than $20,000.
YOU CAN BUY IT FOR $6000.00 OR BUY BOTH BUCKETS FOR $13,000.00
With its large 1.8-yard volume, this bucket will pay for itself on the first difficult digging job RATHER THAN RIPPER, saving time when loading trucks.
Unlike Ritchie's Brothers Sell, these American-made buckets are made of better steel or quality ESCO Foundry T-1. There is no junk from China here.
FROM THE WEBSITE OF ESCO:
Heavy-Duty Excavator Pail (XDP)
The XDP bucket is designed to handle demanding overburden excavation tasks.
When top-loading or excavating rock material, the XDP bucket performs better.
What XDP offers is
Gussets on the lip and beam that increase durability in corners under high stress.
T1 steel single-piece reinforcing plates to increase side plate durability and strength.
Under the lugs, a 400 Brinell bottom runner provides complete abrasion resistance and extra structural integrity.
SERVICES - BUCKET PIPELINE
Custom-built ESCO bucket with four ESCO HD teeth that measures 32 inches wide outside on the extreme duty side cutters and 30 inches across when side cutters are not present.
A LOT OF HARD SURFACE WELDING HAS BEEN DONE FOR SET OR EXTREME DUTY SIDE CUTTERS ON ALL WEAR SURFACES.
BUCKET'S HIGH CAPACITY DESIGN ALLOWS IT TO DO HEAVY DUTY WORK WHEN LOADING TRUCKS.
604-476-7777 FRANK
The bucket is ready to work after being factory reinforced with new teeth, a complete additional T-1 plate double bottom, and additional wear bottom bars. It also underwent days of hard surfacing.
THIS NEW ESCO BUCKET IS MORE THAN $15,000.
Either take it for $8000.00, or for $15,000.00, take both buckets.
When the first trenching job is completed on schedule, this bucket will pay for itself.
BUCKETS ARE AT OUR YARD LANGLEY BC - WE GET VERY GOOD RATES DELIVERED TO YOUR DORR WITH GREAT FAST SHIPPING
What XDP offers is:
Gussets made of lip and beam that offer more durability in corners with high stress.
