NEW FLECO 24 INCH & WBM 36 INCH 250-400 CLASS EXCAVATOR EXTREME DUTY DIGGING BUCKETS
Price: $6000.00
250 - 400 CLASS EXCAVATORS TAKE YOU CHOICE OF BUCKET FOR $6000.00  NEW THESE BUCKETS ARE OVER $12,000 EACH AND 4 MONTHS LEAD TIME
BOOTH BUCKETS HAVE 90 MM FRONT PINS WILL FIT ANY PIN GRABBERS COUPLER THAT TAKES 90 OR 100 MM FRONT PINS
WE BOUGHT TO PUT ON OUR LONG REACH 500 CLASS CUSTOM BUILT PC450LC-8 EXCAVATOR FOR DIGGING BETWEEN PILES IN PILE DRIVING EXCAVATIONS WHERE THE PILES ARE DRIVEN BEFORE EXCAVATION SHEET PILES ARE DRIVING AROUND EXCAVATION AND THEN EXCAVATED
FLECO Heavy-Duty Excavator Buckets are designed for digging in a broad range of materials including dirt and clay. FLECO uses AR400 Steel on the Side Wear Plates, Cutting Edges, Mounting Brackets and reinforcing Wear Bars. AR400 is much stronger and wear resistant than T1 Structural Steel. FLECO Bucket Shells are rolled and constructed from A-572-50 Steel.
Designed with Heavy-Duty AR400 Steel
All Excavator Buckets are built to OEM Specifications
Equipped with Thick Wear Straps and Wear Pads
Included with Standard J-Series Style Teeth
Included with D-Ring
Optional Side Cutters (12K lbs. Class & Up)
Optional Dead Pins
MANUFACTURERS
CAT, CASE, KOBELCO, SANY, JOHN DEERE, HITACHI, KOMATSU, TAKEUCHI, KUBOTA, LINK BELT, VOLVO, HYUNDAI, LUI GONG, NEW HOLLAND, DOOSAN, JCB, SAMSUNG, DAEWOO, KAWASAKI, YANMAR, BOBCAT
WBM’S HEAVY DUTY EXCAVATOR BUCKET WORKS IN ALL GENERAL PURPOSE AND HEAVY-DUTY DIGGING APPLICATIONS.
Request Brochure >>
FEATURES & BENEFITS OF HEAVY-DUTY EXCAVATOR BUCKET
  • Dual tapered design for easy clean-out
  • Available in a full range of sizes
  • Reduces cycle time by optimizing machine’s breakout and crowd forces
  • Heavy-duty construction increases wear life
  • Superior loading capabilities
STANDARD EQUIPMENT FOR BUCKET
  • 100,000 yield WBM coupler lugging
  • Heavy-duty long-life teeth
  • Reinforced upper corners
  • Engineering certified lifting lug
  • 450 Brinell leading-edge drilled for side cutters
  • 450 Brinell base edge
  • 450 Brinell horizontal wear bars
  • 450 Brinell outside cheek plates
OPTIONAL EQUIPMENT FOR EXCAVATOR BUCKET
  • Customer preferred brand of tooth
  • Bolt-on side cutters
  • Pin-on lugs
  • Leading-edge protectors
WILL SHIP NEXT BUSINESS DAY WE GET GREAT RATES
