OKADA ORV7500 โ Mid-Class Hydraulic Breaker 30 -45 TON ECAVATOR ONCRETE - ROCK HAMMER
Price: $45000.00
๐ Factory Shop Rebuilt with 6-Month Okada Factory Warranty ๐
๐ Location: Langley, BC (Ships directly from our yard)
๐ฐ Price:ย $45,000.00 CAD (New unit costs $105,000.00 from Okada)
Key Features & Details:
- 2020 Model, purchased in 2020, but now considered a 2023 unit after a full Stage 2 rebuild.
- Complete rebuild performed at Okadaโs Oregon factory ($27,000.00 USD / $37,000.00 CAD).
- Rebuild Includes:
- All new bushings.
- New seal kit.
- New pistons.
- 1 brand new & 1 slightly used original Okada Moil Point (2 total).
- Resealed at Okada Factory Repair Shop (only used lightly before COVID; resealed due to sitting idle).
- New nitrogen charge for optimal performance.
๐ ๏ธ Ready to Work - Okada ORV7500 Hydraulic Demo Hammer Breaker Chisel Attachment Tool
๐น Low-hour 7500 ft-lb hammer, used for onlyย one job before COVID.
๐นย Invoice Available (See image #3).
๐นย Factory-tested & certified rebuild with warranty.
๐น Shipped on our account for fast service & great rates.
๐ฒ Price:ย $45,000.00 CAD
Why Choose the Okada ORV7500?
๐นย Auto-Lube System: Easily adaptable to most automatic lubrication setups.
๐น Main Valve: Internal control valve systemย increases impact energy while keeping temperatures lower.
๐นย Large Capacity Accumulator: Reduces shock load in the system.
๐น Stroke Adjuster: Variable speed controlย maximizes productivity.
๐นย Original Holding System: Secure powercell placement reduces recoil.
๐น Larger N2 Gas Chamber: Ensuresย high-impact power.
๐น Long Stroke Piston: Boosts impact power while reducing vibration & recoil.
๐น Dual Chisel Retaining Pin: Heavy-duty pins extendย service life.
๐น Durable Breaker Bracket: Heavy-duty bottom plate for noise & vibration reduction.
Technical Specifications:
- Impact Energy Class: 7500 ft-lb / 10,170 Joules
- Operating Weight: 5,950 lbs / 2,698 kg
- Oil Flow: 63-72 gpm / 238-272 lpm
- Frequency:
- L-Mode: 230-400 bpm
- S-Mode: 270-470 bpm
- Operating Pressure: 2,320-2,600 psi / 157-180 bar
- Mechanical Energy: 98-133 HP / 73.4-99.5 kW
- Mechanical Energy (Avg): 115.5 HP / 86 kW
- Unit Working Length: 124 in / 315 cm
- Tool Diameter: 6.1 in / 155 mm
- Tool Working Length: 30.2 in / 767 mm
- Noise Level: 85 dB(A) at 119-167 ft / 36-51 m
- Carrier Weight Range: 60-92 lbs / 27-42 M ton
๐ข Bonus Deal:
We also have a $80K New Old Stock Okada Demolition Processor for 200-350 class machines โ Available for $25,000.00! (Check our other ads)
๐ Contact:
Frank - 604-476-7777
