Simex TF 1100 Cutter Head – For 200–350 Class Excavators βœ… Low Hour Demo Model – 35" Excavator Rotary Cutter Head For 36 Inch Trenching
Price: $75000.00
πŸ”§ Simex TF 1100 Cutter Head – For 200–350 Class Excavators
βœ… Low Hour Demo Model – 35" Excavator Rotary Cutter Head For 36 Inch TrenchingΒ
  • Mount Specs: Β  Β
    • 90 mm diameter pins
    • Β  Β  Β
    • 485 mm center-to-center (pin boss)
    • Β  Β  Β
    • 360 mm inside-to-inside pin boss spacing
πŸ”© Key Features:
  • Designed for trenching, profiling, cutting rock and cement walls, tunneling, quarrying, demolition, dredging, and even underwater applications
  • Β
  • Especially effective where conventional excavation methods fail and percussion tools are ineffective
  • Β
  • Ideal for carrier weight of 20 to 34 tons (excavators in the 200–350 class)
  • Β
  • Quiet operation makes it suitable for sensitive areas such as: Β  Β
    • Residential zones
    • Β  Β  Β
    • Schools
    • Β  Β  Β
    • Hospitals
    • Β  Β  Β
    • Bridges and critical infrastructure
βš™οΈ Performance Specs:
  • Oil Flow Range: 45–66 liters per minute
  • Β
  • Max Operating Pressure: 5800 PSI
  • Β
  • Cutting Speed: 2.2 – 3.5 meters per minute
  • Β
  • Cutting Width: 35 inches – perfect for deep, narrow trenching
🎯 Operator Benefits:
  • Highly balanced and controllable, making it easier to handle
  • Β
  • Allows for efficient corner cutting and precision work
  • Β
  • Recommended for finishing operations with: Β  Β
    • High precision
    • Β  Β  Β
    • Minimal disturbance
    • Β  Β  Β
    • Superior aesthetic results
πŸ’° As New Cost:
$125,000.00 USD
(Approx. $170,000.00 CAD) – Great value for a low-hour demo unit!
πŸ“½οΈ See It in Action:
πŸ”— Watch on YouTube: https://youtu.be/BHGg1d8aLYY?si=09FO62UqLZm5Ughy
πŸ“ Location:
1921 Lakeview Rd, Cambridge Narrows, New Brunswick E4C 1N
πŸ“ž Contact Frank: Β Β 604-476-7777
