Simex TF 1100 DUAL DRUM CUTTER HEAD 240 – 450 Class Excavators - MINING - ROCK SCALING - CEMENT DEMOLTITION
Price: $75000.00
✅ Low Hour Demo Model – 35" Excavator Rotary Cutter Head For 36 Inch Trenching  and Concrete Resurfacing and Demolition of Wall and Slabs
    * Mount Specs:
          o 90 mm diameter pins
          o 485 mm center-to-center (pin boss)
          o 360 mm inside-to-inside pin boss spacing
ORIGINAL PAINT - DECALS AND CUTTING PICKS (TEETH) - HOSES ARE LIKE NEW - READY TO WORK
 Key Features:
    * Designed for trenching, profiling, cutting rock and cement walls, tunneling, quarrying, demolition, dredging, and even underwater applications
    * Especially effective where conventional excavation methods fail and percussion tools are ineffective
    * Ideal for carrier weight of 28 to 45 tons (excavators in the 240–450 class)
    * Quiet operation makes it suitable for sensitive areas such as:
          o Residential zones
          o Schools
          o Hospitals
          o Bridges and critical infrastructure
⚙️ Performance Specs:
    * Oil Flow Range: 45–70 GALLONS per minute - MINIMAL 122 HORSE POWER
    * Max Operating Pressure: 5800 PSI
    * Cutting Speed: 2.2 – 3.5 meters per minute
    * Cutting Width: 35 inches – perfect for deep, narrow trenching
 Operator Benefits:
    * Highly balanced and controllable, making it easier to handle
    * Allows for efficient corner cutting and precision work
    * Recommended for finishing operations with:
          o High precision
          o Minimal disturbance
          o Superior aesthetic results
PRODUCES EXCAVATED  FINISHED 1 1/2  TO 4 INCH MATERIAL PERFECT FOR ROAD BASE OR BACK FILLING
 As New Cost c/w 300-350 class pin on / pin grabber wounting plate and hoses:  $125,000.00 USD
(Approx. $170,000.00 CAD) – Great value for a low-hour demo unit!
️ See It in Action:
 Watch on YouTube: https://youtu.be/BHGg1d8aLYY?si=09FO62UqLZm5Ughy
1921 Lakeview Rd, Cambridge Narrows, New Brunswick E4C 1N
 Contact Frank:   604-476-7777
