Simex TF 1100 Dual Drum Cutter Head For 200–350 Class Excavators - OUTPERFORMS HAMMERS IN TRENCHING - ROCK FACING - EXCAVATING X 3-5 TIMES
Price: $60000.00
 WHICH OUTPERFORMS HAMMERS IN TRENCHING - ROCK FACING - EXCAVATING  X 3-5 TIMES
 Watch Others  in Action – Performance Comparison Videos
▶️ Hydraulic Hammer vs. Dual Drum Grinder
 https://www.youtube.com/watch?v=r55VlxS750g
▶️ Terex Dual Drum Cutter – Real Jobsite Footage
 https://www.youtube.com/watch?v=rSleaL-FoCo
Available Now –  Canada-Wide Shipping
The Simex TF 1100 dual drum grinder is designed for excavators in the 20–34 ton range. It features a drum width of 850 mm (34 inches) and requires an oil flow of 170–250 l/min (45–66 GPM) at a maximum pressure of 400 bar (5800 PSI). With a nominal power of 90 kW (122 HP), rotation torque of 20 kNm (14,750 lbf·ft), and cutting force of 61 kN (13,700 lbf), the TF1100 delivers serious performance in harsh conditions. The base unit weighs 1,340 kg (2,950 lbs) without the pin mounting bracket which is included c/w pins.
 Detailed Technical Overview
Excavator Compatibility: Suited for 20–34 ton (44,000–80,000 lb) class machines
Cutting Width: 850 mm (34 inches)
Oil Flow Requirement: 170–250 L/min (45–66 GPM)
Operating Pressure: 400 bar (5800 PSI)
Nominal Power: 90 kW (122 HP)
Rotation Torque: 20 kNm (14,750 lbf·ft)
Cutting Force: 61 kN (13,700 lbf)
Weight: 1,340 kg (2,950 lbs) without the pin on mounting bracket which is included c/w pins
Additional Features:
Replaceable anti-wear plates
Double support bearings per drum
Advanced sealing system to prevent dust and impurities from entering the motor
 Key Highlights
✅ Engineered for Precision & Power – Built for tough conditions and extreme materials
✅ Low Noise & Minimal Vibration – Ideal for sensitive or urban environments
✅ Outperforms Traditional Excavation Tools – Faster, cleaner, and more efficient results
✅ Versatile Across Industries – Construction, mining, dredging, and demolition ready
⚙️ Technical Specifications
Reference Number: AMH088
Operating Weight: 1,340 kg
Carrier Excavator Range: 200–350 Class
Oil Flow Rate: 170–250 L/min
Maximum Pressure: 400 bar
Rated Power: 122 HP
 Performance Features
 20 kNm Rotation Torque – Delivers aggressive, consistent power
️ Drums & Teeth Configurable for Various Applications
 Replaceable Anti-Wear Plates – Built for long service life
️ Dust-Sealed Mechanical Drums – Reduces maintenance downtime
 High Torque / Efficiency Ratio – Maximum productivity, minimal energy loss
️ Double Drum Support Bearings – Rugged design for continuous use
 Efficient Debris Removal System
⚙️ Advanced Cutter Design – Superior cutting depth and visual results
 Ideal Applications
Trenching & Pipeline Installation
Rock & Concrete Profiling
Tunnel Excavation
Quarry Operations
Dredging & Marine Construction
Final Surface Finishing
Underwater Demolition
 Availability & Contact
 Location: 1921 Lakeview Rd, Cambridge Narrows, NB, E4C 1N1
 Shipping: Available Canada-wide
 Contact: Frank Rayner – 604-476-7777 call - text - WhatsApp
✉ Email: [email protected]
 Browse More Equipment: https://www.alltrac.co
