TERMINATOR TX750 – 75,000 ft-lb Gravity Drop Rock - Boulder - Excavation - Concrete Wall - Slabs - Bridge Decks - Breaker / Hammer - Steel Slag etc
Price: $75000.00
Extreme Demolition Power • Low Hours • $75,000 CAD
SEE AND DOWNLOAD ROCKTEC FACTORY SERVICE AND PARTS MANUAL (copy and paste)
https://drive.google.com/file/d/1luo6aO-JXn7LjLCsnYYLwEr8iIlNYZvB/view
( Replacement Value: $164,000+ USD = $225,000.00 CDN) see image 4 for quote for a Surestrike MUCH SMALLER 50,000 Ft LB Drop Hammer ) plus now add the rising price of steel and Trumps Tarriffs - 7 WEEKS lead time - shipping from US - this TX750 unit is ready to ship now - have at the quarry or on the demo site next week.
NOTE :  THE EQUIVALENT MODEL SS80 SURESTRIKE 80,000 FT LB DROP HAMMER HAS TO GO ON A 650 OR LARGER EXCAVATOR AND COSTS $225,000.00 USD  (COPY AND PASTE)
  https://surestrikeinternational.com/product-portfolio/ss80/
WATCH THE THIS  VIDEO TO SEE THE TX750 ON A 988 CAT LOADER BUSTING 5 CUBIC METER GRANITE IN 1 BLOW :
https://youtube.com/watch?v=hS3GBw-HFKA
 Overview
Model: TX75000 Terminator Gravity Drop Hammer
Impact Energy: Massive 75,000 ft-lb per strike
Purpose: High-production demolition – concrete 4 foot or thicked slabs & walls - airport runways - bridge decks,  granite banks , slabs, and large oversized boulders and rocks.
Condition: Excellent – low operating hours - just checked out by our mechanic - loader top plate removed - original paint - decals and breaker point.
Price: $75,000 CAD
Appraised Value: Over $164,000 + USD plus costs and months of lead times for a MUCH SMALLER  SURESTRIKE
️ Carrier Compatibility
Excavators: Fits 350–800 class machines as boom mount 2nd member or 400 - 800 class as stick mount 3rd member.
 Ideal Solution for Older Excavators – Boost Profit with Minimal Stress
✅ Perfect Compatibility:
Designed for older excavators equipped with only a single auxiliary hydraulic function
✅ Zero Stress Operation:
No downforce required
No crowding or pressure on boom, stick, or swing (rotec)
The Terminator does all the work – simply rest it on the surface to break
✅ Protects Your Equipment:
No hydraulic stress on your excavator
No overheating of hydraulic oil
Extends the service life of aging machines
✅ Highly Profitable Add-On:
Adds $250.00+ per hour to your base machine rate
Turns retired or underused excavators into active revenue generators
✅ Exceptional ROI:
Great source of income with minimal maintenance and wear
Allows older equipment to stay productive without costly upgrades
Three Top Mounting Plates for the Terminator Drop Hammer
Includes mounting options for quick adaptability to various machines. Ideal for quarry, demolition, or recycling use.
✅ 988 Cat Q/C Plate (Quick Coupler Plate)
Currently removed from the hammer which was being prepped to fit the two included excavator mounts.
Both excavator mounts have identical bolt patterns and can be swapped interchangeably
✅ Mounting Plate 1 – New, Never Installed
120 mm case-hardened pins installed
Can be bushed down to 110 mm or  (lathe-centered)
Distance between ears: 17 inches
Pin center-to-center spacing: 22 ¾ inches
✅ Mounting Plate 2 – Lightly Used, Like New
100 mm pins installed
 Frank — 604-476-7777
 Ready to ship quickly — we secure excellent freight rates Canada-wide!
✅ Key Features & Benefits
 Maximum Demolition Power
Breaks 4-foot-thick concrete and 10 ft boulders in a few hits
Efficient rebar separation from reinforced concrete
⚡ Superior to Hydraulic Hammers
3–10x faster at block-breaking (depending on rock hardness)
2–5x more efficient for trenching, road building, quarry use, and demolition
No hydraulic overload = longer life for pumps and components
Fewer strikes = reduced noise and wear
 Operator & Machine Friendly
Minimal vibration for operator comfort
No carrier shock = preserves boom, frame, and components
Functions at any angle, even 30 degrees – no damage to machine
 Low Maintenance Design
No lube system required , no overheating
No electronics, no rebuild cycles
Replaceable strap component in minutes
Dry-hit safety system built-in
Striker pin lasts many times longer than alternatives as never gets hot
 Versatile & Flexible
Mounts to excavators and wheel loaders
Compatible with most quick hitch systems
Ideal across applications:
Demolition - concrete slabs - bridge decks - thick runways - concrete walls
Armor stone & boulders
Quarry rock
Civil foundations
Steel mill slag
Road and trench work
➕ Optional Add-On (Sold Separately)
️ Custom 30-Foot Certified Stick
For Volvo EC700/EC750 or other 600–850 class excavators that would be:
Ideal for pile driving (steel, concrete, wood)
Minor boom mods may be required for fitment
 Video Demonstrations - Note: THESE ARE ALL SMALLER UNITS THAN THE TX7500
Demo 1 – Concrete & Rock Breaking:
https://www.youtube.com/watch?v=3aLixK1EP5U
Demo 2 – Quarry Operations:
https://www.youtube.com/watch?v=ygEyR3GO7Y4
https://www.youtube.com/watch?v=TAkDUP_figA&t
(Additional videos available on request)
 Location
Cambridge Narrows, New Brunswick, Canada
 Shipping
North American shipping available (excluding Mexico)
Competitive freight rates arranged
 Contact Frank
Call / Text / WhatsApp: 604-476-7777
Website: www.alltrac.co
Note: EMAILS WILL BE IGNORED – CALL OR TEXT - WHATSAP  ONLY  Frank 604-476-7777
 The Terminator® TX75000 – A Game-Changer When Blasting Isn’t an Option
When blasting is restricted or not feasible, TERMINATOR® becomes the most profitable and powerful alternative.
 Performance Metrics
 Block Breaking:
3–10x better performance than conventional hammers
 Roadwork & Quarrying:
2–5x better performance on trenching, extraction, demolition
 Armor Stone:
3x more efficient than blasting
Yields 50–80% usable stone (vs. ~20% from blasting)
 Competitive Advantage:
Out-produces:
Other gravity hammers
Chemical rock breaking
Vibrating rippers
 Key Applications:
 Mining & Quarrying of Hard Rock
Ideal for medium-strength, low-abrasive seamed rock
Used for 60%+ of all quarry and surface-mined rock
️ Civil Construction
Road building and excavation on hard or fractured ground
Hits 5x harder than traditional hydraulic hammers
 Armor Stone & Oversized Rock
Breaks large boulders faster and cleaner than blasting
Less excavation = millions of tonnes saved
 Demolition & Excavation
Breaks ultra-thick, high-strength concrete
Up to 5x faster on:
Bridges
Docks
Pilings
Power stations
Military-grade structures
♻️ Steel Reprocessing
Recycles slag for steel mill reuse
Makes spec sizes at 2–3x the speed of competitors
⚙️ How It Works – Principle of Operation
Massive weight is lifted and dropped onto a striker pin
Creates over 5x more impact energy than the largest hydraulic hammers
Strikes are fully operator-controlled
Can operate at any angle
Minimal vibration = no damage to carrier
No cycling strain on hydraulics, pumps, or excavator frame
 Capital Cost Advantage & Profitability
More profitable than blasting in almost all use cases
Achieve equal or better results with:
1–4 fewer operators
Less fuel
Fewer machines
Preserves excavator value – perfect for older carriers
High resale value across industries (armor stone, steel mills, demolition)
️ Maintenance Made Easy
Simple system = low cost & low downtime
No lube, no seal burn-out, no overheating
STRIKER WEIGHT Strap replacement in minutes - EVERY 1000 HRS - COST $300.00 EACH
No specialist tools or rebuilds required
Dry-hit protection system included
Rebuildable wear parts = lower inventory cost
 Noise & Environmental Impact
Same decibel level per blow as hydraulic hammers
But only 5% of the hits/hour
Faster jobs = lower overall exposure
 Excavator Mounting Notes - Can mount directly to excavators with interchangeable plates - 2 included c/w case hardened pins
For quick coupler mounting, Custom mating parts available for all brands - INCLUDED
✅ Why the Terminator TX75000?
Purpose-built for:
Extreme-duty demolition
Oversized rock reduction
Civil excavation
Non-blasting zones
Steel mill and quarry operations
✔️ Heavy-Duty. Low-Maintenance. High-Impact. Ready to Work.
ADD OUR XCENTRIC XC5000 JAW CRUSHER BUCKET - see ad copy and paste:
https://www.kijiji.ca/v-view-details.html?adId=1585092754
The World’s Most Advanced Excavator Jaw Crusher Bucket - Replaces $400,000+ Mobile Crushers — A Game-Changer for On-Site Crushing
Compact, Powerful, and Efficient:
Superior to Traditional Mobile Crushers:
- Eliminates the need for a separate loader
- Works efficiently in tight or restricted job sites
- Adjusts output sizing in just 2–3 minutes, not hours
- No conveyor belts to rip or fail
- Minimal downtime – designed for reliability, not repairs
Cost-Saving Advantages:
- ½ the fuel consumption
- ½ the insurance cost
- Easily maintained – no complex systems like those in mobile crusher units
Strategic Investment:
- Replaces multiple machines
- Faster set-up and teardown
- Ideal for demolition, quarrying, and remote sites
Performance Highlights:
Crushing Output: Over 130+ Yards Per Hour
Capable of breaking: Reinforced concrete (rebar included), hard granite, basalt, wet or dry demolition debris
Replaces On-Site Jaw Crusher:
- Load output directly into 10 tandem 13 CUBIC YARD dump trucks per hour
- Stockpiles with quickly adjustable aggregate sizing
Output Size Adjustable:
- 1/2" - 1½" minus to 5" product
- Granulometry adjusted in under 5 minutes (just drive 2 pins to adjust jaws)
Pricing:
New Replacement Value: $250,000+ USD
Your Price: $125,000.00 CAD
OR TAKE BOTH UNITS FOR $200,000.00 CDN PLUS SHIPPING -  DISCOUNT OFF $400,000.00 PLUS USD QUALITY EQUIPMENT  - NO 7 WEEK WAITS - NO TARRIFFS - NO CUSTOMS ISSUES
FRANK 604-476-7777 - CALL - TEXT OR WHATAPP
NO EMAILS WILL NOT BE ANSWERED
 APPLICATIONS – THE TERMINATOR® ROCK BREAKER
The Terminator® is an ultra-versatile attachment that outperforms conventional hammers, gravity hammers, and vibrating rippers in nearly every application.
✅ Mining & Quarrying of Hard Rock
Ideal for medium strength, seamed, low-abrasive rock — over 60% of all quarried material.
Performs exceptionally in surface mining and open pit operations.
Replaces costly and less effective blasting in many scenarios.
✅ Civil Construction
Excels in road building, trenching, and foundation excavation.
Breaks difficult ground with long reach and massive impact energy.
Hits up to 5× harder than conventional hammers, even near-horizontal.
✅ Armor Stone & Oversize Rock Breaking
Delivers 50–80% usable stone yield vs. only 20% from blasting.
On large projects (e.g., 1 million tonnes), reduces total required material extraction by up to 3 million tonnes.
The go-to solution for oversized rock reduction.
✅ Demolition & Excavation
Breaks concrete of any thickness or strength – bridges, pilings, docks, power plants, military-grade structures.
Up to 5× faster than standard hydraulic hammers.
No need for pre-cracking or staged reduction – raw power, controlled impact.
✅ Steel Reprocessing
Efficiently breaks slag to extract steel for recycling.
Produces spec-size material at 2–3× the rate of competing gravity hammers.
Ideal for mill feed preparation and heavy-duty industrial use.
⚙️ PRINCIPLE OF OPERATION – HOW TERMINATOR® WORKS
Utilizes a massive free-fall weight that strikes a large striker pin to deliver over 10× the energy of conventional hydraulic hammers.
Fully operator-controlled power – precision with every blow.
Multi-angle operation – vertical, horizontal, and even upward impact without damage.
The striker pin doubles as a levering/prying tool for boulder manipulation.
 Why Conventional Hammers Can’t Compete:
Must be forced hard against rock to work.
Rely on carrier weight – transferring damaging shock loads to the boom, frame, and operator.
Cause hydraulic system stress, frequent breakdowns, and costly repairs.
✅ Why Contractors Choose the Terminator®:
Rested, not forced – reduces stress on operator and equipment.
No high-cycle hydraulics – preserves pumps and machine longevity.
Minimal vibration and no backshock – safe, smooth, and powerful.
Unmatched efficiency in the field across all rock breaking applications.
