TX 75000 FT LB IMPACT HAMMER / BREAKER 450 - 800 EXCAVATOR TERMINATOR TX75000 – 75,000 ft-lb Gravity Drop Breaker Extreme Demolition Power
Price: $75000.00
TERMINATOR TX75000 – 75,000 ft-lb Gravity Drop Rock - Boulder - Excavation -  Concrete Wall - Slab - Bridge Decks - Breaker
Extreme Demolition Power • Low Hours • $75,000 CAD
(Professionally Appraised Replacement Value: $164,000+ USD see image 4 for quote for a Surestrike Smaller 50,000 Ft LB Drop Hammer ) plus now add the rising price of steel and Trumps Tarriffs - lead time - shipping from US - this unit is ready to ship now - have at the quarry or on the demo site next week.
NOTE :  THE EQUIVALENT MODEL SURESTRIKE 80,000 FT LB DROP HAMMER HAS TO GO ON A 650 OR LARGER EXCAVATOR AND COSTS $225,000.00 USD  (COPY AND PASTE)
  https://surestrikeinternational.com/product-portfolio/ss80/
WATCH THE POSTED VIDEO TO SEE THE TX750 ON A 988 CAT LOADER BUSTING 5 CUBIC METER GRANITE IN 1 BLOW
 Overview
Model: TX75000 Terminator Gravity Drop Hammer
Impact Energy: Massive 75,000 ft-lb per strike
Purpose: High-production demolition – concrete, granite, slabs, and oversized boulders
Condition: Excellent – low operating hours
Price: $75,000 CAD
Appraised Value: Over $164,000 + USD plus costs and months of lead times
️ Carrier Compatibility
Excavators: Fits 450–800 class machines
Wheel Loaders: Mounts to 80,000 lb+ machines (e.g., CAT 988)
 Mounting Options Included
Excavator mounting brackets - have several choices excavator brackets c/w pins that you can have quickly modified to fit your excavator.
CAT 988 Quick Coupler (Q/C) loader brackets
✅ Key Features & Benefits
 Maximum Demolition Power
Breaks 4-foot-thick concrete and 10 ft boulders in a few hits
Efficient rebar separation from reinforced concrete
⚡ Superior to Hydraulic Hammers
3–10x faster at block-breaking (depending on rock hardness)
2–5x more efficient for trenching, road building, quarry use, and demolition
No hydraulic overload = longer life for pumps and components
Fewer strikes = reduced noise and wear
 Operator & Machine Friendly
Minimal vibration for operator comfort
No carrier shock = preserves boom, frame, and components
Functions at any angle, even 30 degrees – no damage to machine
 Low Maintenance Design
No lube system, no overheating
No electronics, no rebuild cycles
Replaceable strap component in minutes
Dry-hit safety system built-in
Striker pin lasts many times longer than alternatives as never gets hot
 Versatile & Flexible
Mounts to excavators and wheel loaders
Compatible with most quick hitch systems
Ideal across applications:
Demolition
Armor stone & boulders
Quarry rock
Civil foundations
Steel mill slag
Road and trench work
➕ Optional Add-On (Sold Separately)
️ Custom 30-Foot Certified Stick
For Volvo EC700/EC750 or other 600–850 class excavators that would be:
Ideal for pile driving (steel, concrete, wood)
Minor boom mods may be required for fitment
 Video Demonstrations
Demo 1 – Concrete & Rock Breaking:
https://www.youtube.com/watch?v=3aLixK1EP5U
Demo 2 – Quarry Operation:
https://www.youtube.com/watch?v=ygEyR3GO7Y4
(Additional videos available on request)
 Location
Cambridge Narrows, New Brunswick, Canada
 Shipping
North American shipping available (excluding Mexico)
Competitive freight rates arranged
 Contact Frank
Call / Text / WhatsApp: 604-476-7777
Website: www.alltrac.co
Note: EMAILS WILL BE IGNORED – CALL OR TEXT ONLY
 The Terminator® TX75000 – A Game-Changer When Blasting Isn’t an Option
When blasting is restricted or not feasible, TERMINATOR® becomes the most profitable and powerful alternative.
 Performance Metrics
 Block Breaking:
3–10x better performance than conventional hammers
 Roadwork & Quarrying:
2–5x better performance on trenching, extraction, demolition
 Armor Stone:
3x more efficient than blasting
Yields 50–80% usable stone (vs. ~20% from blasting)
 Competitive Advantage:
Out-produces:
Other gravity hammers
Chemical rock breaking
Vibrating rippers
 Key Applications
 Mining & Quarrying of Hard Rock
Ideal for medium-strength, low-abrasive seamed rock
Used for 60%+ of all quarry and surface-mined rock
️ Civil Construction
Road building and excavation on hard or fractured ground
Hits 5x harder than traditional hydraulic hammers
 Armor Stone & Oversized Rock
Breaks large boulders faster and cleaner than blasting
Less excavation = millions of tonnes saved
 Demolition & Excavation
Breaks ultra-thick, high-strength concrete
Up to 5x faster on:
Bridges
Docks
Pilings
Power stations
Military-grade structures
♻️ Steel Reprocessing
Recycles slag for steel mill reuse
Makes spec sizes at 2–3x the speed of competitors
⚙️ How It Works – Principle of Operation
Massive weight is lifted and dropped onto a striker pin
Creates over 10x more impact energy than the largest hydraulic hammers
Strikes are fully operator-controlled
Can operate at any angle, including upward
Minimal vibration = no damage to carrier
No cycling strain on hydraulics, pumps, or excavator frame
 Capital Cost Advantage & Profitability
More profitable than blasting in almost all use cases
Achieve equal or better results with:
1–4 fewer operators
Less fuel
Fewer machines
Preserves excavator value – perfect for older carriers
High resale value across industries (armor stone, steel mills, demolition)
️ Maintenance Made Easy
Simple system = low cost & low downtime
No lube, no seal burn-out, no overheating
Strap replacement in minutes
No specialist tools or rebuilds required
Dry-hit protection system included
Rebuildable wear parts = lower inventory cost
 Noise & Environmental Impact
Same decibel level per blow as hydraulic hammers
But only 5% of the hits/hour
Faster jobs = lower overall exposure
 Excavator Mounting Notes
Can mount directly to excavators
For quick coupler mounting, increase carrier weight by 15%
Custom mating parts available for all brands
✅ Why the Terminator TX75000?
Purpose-built for:
Extreme-duty demolition
Oversized rock reduction
Civil excavation
Non-blasting zones
Steel mill and quarry operations
✔️ Heavy-Duty. Low-Maintenance. High-Impact. Ready to Work.
ADD OUR XCENTRIC XC5000 JAW CRUSHER BUCKET AND CRUSH THE BROKEN BOULDERS OR CONCRETE WITH THE SAME MACHINE ANYWHERE IN QUARRY OR ON THE DEMO SITE AT 130 YARDS PER HOUR FROM 1 INCH MINUS TO 5 INCH MINUS - COPY And PASTE
https://www.kijiji.ca/v-view-details.html?adId=1585092754
