XCENTRIC XC50 400-650 CLASS EXCAVATOR CONCRETE - ROCK - GRANITE JAW CRUSHER BUCKET 130 YARDS PER HOUR
Price: $125000.00
The World’s Most Advanced Excavator Jaw Crusher  Bucket
  Currently located at Quality Blasting & Coating (NS) – undergoing full sandblast, anti-corrosion undercoating, epoxy repaint, and new factory decals.
 Performance Highlights:
✅ Crushing Output: Over 100+ Yards Per Hour
Capable of breaking:
Hard granite, basalt
Wet or dry demolition debris
Load output directly into:
10 tandem dump trucks per hour
✅ Output Size Adjustable:
1½" minus to 5" product
Granulometry adjusted in under 5 minutes (just drive 2 pins)
 Pricing:
 New Replacement Value: $250,000+ USD
 Your Price: $150,000.00 CAD REDUCED TO $125,000.00
⚠️ Compare: Smaller XC29 (½ the size) from Shearforce retails for $145,000 CAD - see image #6
 Technical Specs:
Model: XC50
Year: 2020
Weight: 6,250 kg
Jaw Opening: 1100 mm x 500 mm
Crushing Volume: 1.5 m³ per bucket
Stock #: XC50
 Engineering Advantages:
 Minimal Maintenance Required:
Grease only every 200 hours
Factory Manual for Excentric Buckets:
Watch It in Action:
▶️ Model-Specific Demo:
 Learn More from the Manufacturer:
 Contact:
Frank Rayner  Phone/Text/WhatsApp: 604-476-7777
 Why This Unit?
✅ Low-hour, was original-paint, now professionally reconditioned
PLEASE SEE MY OTHER LISTINGS FOR THE ROCKTEC TERMINATOR  TX750 450-750 CLASS EXCAVATOR 75,000 FT LB HYDRAULIC DROP HAMMER FOR CONCRETE WALLS - SLABS TO 4 FEET THICK - SHATTERING ROCKS AND BOULDERS 1 TO 10 CUBIC METERS TO THEN RUN THROUGH THIS JAW CRUSHER BUCKET
