2006 Kenworth C500B – 40-Ton Weldco Hydraulic Crane Truck
Posted Date: Aug 1st, 2025 at 04:21 AM
Price: $105000.00
Heavy-Duty | High-Capacity | Built for the Toughest Jobs
🔧 Truck Specifications:
  • Make/Model: Kenworth C500B
  • Year: 2006
  • Engine: Cummins or CAT Diesel (confirm exact model)
  • Transmission: Eaton Fuller manual (confirm speed)
  • Drive: Likely 6x6 heavy-duty drivetrain (confirm configuration)
  • Cab: Day cab with air-ride seat, heat, and A/C
  • GVWR: Built for extreme heavy-duty applications
🔧 Crane Specifications:
  • Brand/Model: Weldco Hydraulic Crane
  • Capacity: 40 tons (80,000 lbs)
  • Boom Length: [Insert length if known] hydraulic telescopic main boom
  • Jib: Optional jib for extended reach (if included)
  • Controls: Hydraulic control levers in operator station
  • Condition: Well-maintained and fully operational
  • Heavy-duty Kenworth C500B chassis built for extreme crane and hauling work
  • Weldco 40-ton crane for serious lifting capacity
  • Ideal for oilfield, construction, industrial, and infrastructure lifting operations
  • Strong, reliable diesel powertrain with excellent pulling and lifting capability
  • Steel heavy-duty crane bed with stabilizers for maximum stability
  • Maintained for performance and safety – ready for immediate work
  • Oilfield and rigging operations
  • Industrial and construction heavy lifting
  • Infrastructure and utility work
  • Large equipment installation and removal
