2008 Link-Belt RTC-8090 Series II – 90-Ton 4x4 Off-Road Hydraulic Crane
Posted Date: Aug 1st, 2025 at 04:23 AM
High-Capacity Lifting | Rough Terrain Performance | Financing Available
🔧 Crane Specifications:
  • Make/Model: Link-Belt RTC-8090 Series II
  • Year: 2008
  • Lifting Capacity: 90 tons (180,000 lbs)
  • Boom Length: ~38 ft – 140 ft hydraulic main boom
  • Jib Length: ~35 ft – 58 ft offsettable fly jib (optional)
  • Max Tip Height: ~237 ft (with jib)
  • Drive: 4x4 rough terrain
  • Upper Engine: Cummins QSB6.7 (Tier 3)
  • Carrier Engine: Cummins QSB6.7 (Tier 3)
  • Transmission: Powershift – multiple speeds for precise control
  • Hours/Miles: [Insert if known]
  • 90-ton capacity – designed for heavy lifting in demanding environments
  • Rough terrain chassis with 4x4 drive for maximum mobility on job sites
  • Hydraulic telescopic boom for quick extension and retraction
  • Comfortable, climate-controlled operator cab with advanced controls
  • Well-maintained and fully operational
  • Financing available – competitive rates and fast approval
  • Steel erection and industrial construction
  • Bridge and infrastructure projects
  • Oilfield and heavy lifting operations
  • Large equipment installation and removal
