2011 CAT 345DL Excavator – Heavy Lifting. Deep Digging. Built to Perform.
Posted Date: Jul 12th, 2025 at 08:33 PM
Price: $123000.00
🚜 2011 CAT 345DL Excavator – Heavy Lifting. Deep Digging. Built to Perform.
Mass Excavation Power | CAT Reliability | Ideal for Demolition & Site Prep
🔧 Machine Overview – CAT 345DL
  • Make/Model: Caterpillar 345DL
  • Year: 2011
  • Operating Weight: Approx. 110,000 lbs (49,900 kg)
  • Engine: CAT C13 ACERT – Tier 3 Emissions Compliant
  • Horsepower: 345 HP (257 kW)
  • Max Dig Depth: 26 ft 11 in (8.2 m)
  • Max Reach: Over 40 ft at ground level
  • Bucket Capacity: Typically 2.1 – 3.5 cu. yd. (varies by attachment)
  • Undercarriage: Long Carriage (LC) for enhanced stability and lift performance
🛠️ Performance & Hydraulic Features
  • Hydraulic System:
    • Load-sensing hydraulics with flow compensation
    • Strong breakout force and smooth multi-function operation
    • Factory plumbed auxiliary hydraulics for thumb, hammer, shear, or compactor
  • Cooling & Fuel Efficiency:
    • Variable speed fan
    • Auto-idle for fuel savings
    • Extended service intervals for less downtime
👨‍💻 Operator Station
  • Cab:
    • Pressurized, ROPS-certified cab with HVAC system
    • Excellent visibility with large windows and rearview mirrors
  • Controls:
    • Pilot joystick control with adjustable sensitivity
    • CAT electronic monitor with machine diagnostics, alerts, and fuel tracking
  • Seat: Heated, air-suspension with adjustable armrests and lumbar support
Ideal Applications
  • Heavy excavation & mass grading
  • Commercial construction
  • Rock and demolition work
  • Utility trenching and infrastructure
  • Quarry and material loading
🔍 Condition & Inclusions
  • Condition: Well-maintained, work-ready unit
  • Undercarriage: [Insert % wear or recent work done]
  • Hydraulics: Strong and leak-free
  • Includes:
    • Heavy-duty digging bucket
    • Auxiliary hydraulic lines
  • Optional Attachments: Quick coupler, hydraulic thumb, breaker, shear
  • Title: Clean and ready for transfer
💰 Pricing & Financing
  • Competitively priced for a 45-ton class excavator
  • Financing available (OAC)
  • Delivery available nationwide
  • Trade-ins accepted
🔧 Why Choose the 2011 CAT 345DL?
  • Legendary CAT durability and performance in the 45-ton class
  • Still widely supported for parts and service
  • Strong hydraulic system and engine built to handle high-demand work
  • Great fit for contractors needing production-level digging and lifting
  • Reliable machine with a lower cost than Tier 4 Final alternatives
