2013 Kenworth T800 Tri-Drive – Heavy-Duty Fold-Up Crane Truck
Posted Date: Jul 31st, 2025 at 09:24 PM
Extreme Power | High-Capacity | Built for Demanding Jobs
🔧 Truck Specifications:
Make/Model: Kenworth T800 Tri-Drive
Year: 2013
Engine: Cummins ISX or PACCAR MX (confirm exact engine)
Transmission: Eaton Fuller manual (confirm speed)
Drive: Tri-drive (6x8 heavy-duty) for maximum traction and load capacity
Mileage: [Insert mileage if known]
Cab: Day cab with premium interior, air-ride seat, A/C, and heat
GVWR: Extremely high-capacity configuration for crane applications
🔧 Crane Specifications:
Type: Hydraulic fold-up (knuckle boom) crane
Lifting Capacity: [Insert if known, typically 20–40 ton range]
Boom Reach: [Insert reach if known]
Controls: Hydraulic controls and/or remote operation
Condition: Fully functional, well-maintained, and job-ready
Tri-drive chassis for heavy loads and exceptional stability
Fold-up crane for compact transport and quick setup
Heavy-duty suspension and drivetrain for extreme-duty operations
Ideal for oilfield, industrial, and construction lifting
Well-maintained unit – ready to go straight to work
Oilfield and rigging operations
Heavy construction and infrastructure projects
Industrial equipment installation and material handling
Utility and municipal heavy-lift applications
