2016 Elliott Boom Truck Crane – High Reach. Heavy Lift. Built for Productivity.
Posted Date: Jul 8th, 2025 at 10:35 PM
🏗️ 2016 Elliott Boom Truck Crane – High Reach. Heavy Lift. Built for Productivity.
Versatile Workhorse | Sign Installation | Construction | Utilities | Maintenance
🚛 Truck & Chassis Overview
Chassis Make: Typically Freightliner / Peterbilt / International (confirm actual make & model)
Engine: Cummins ISL / PACCAR PX-9 / or Detroit DD13 – Reliable, fuel-efficient diesel engines
Transmission: Allison Automatic or Eaton Fuller Manual – Smooth, dependable, jobsite-ready
Axle Configuration: Tandem Axle (6x4) for balance, payload, and stability
GVWR: Approx. 54,000 – 66,000 lbs (varies by spec)
Cab Features:
Clean, air-ride driver’s seat
PTO switch and crane function display
Cold A/C, AM/FM stereo, and power accessories
Mileage: [Insert actual miles] – Low-mileage, well-maintained fleet unit
Fuel Tanks: Dual tanks – long range without constant refueling
🏗️ Crane Specs – Elliott HiReach or BoomTruck Series
Model: Elliott 36105F, 40142, 45127 or equivalent (confirm model)
Lifting Capacity: Up to 36,000–45,000 lbs (depending on model)
Boom Reach:
Main Boom: 105–142 ft
Jib Extension (if equipped): Up to 200 ft total working height
Crane Type: Telescopic boom with fixed or rotating turret
Rotation: 360° continuous rotation with hydraulic swing
Winch: 2-speed winch with up to 15,000 lbs line pull
Crane Controls:
Dual seated cab or stand-up ground controls
Optional wireless remote for single-operator convenience
Load Moment Indicator (LMI) & anti-two-block system
Stability: Full-span hydraulic outriggers with automatic leveling (if equipped)
Optional Work Platform / Man Basket: OSHA-compliant, hydraulically rotating
🔩 Bed & Body Setup
Bed Length: 20–24 ft steel flatbed with non-slip deck
Deck Features:
Welded D-rings, load binders, stake pockets
Built-in ladder access
Steel headache rack
Tool Storage: Optional side compartments or underbody toolboxes
Condition: Clean, dent-free, crane mounts reinforced, ready to work
✅ Best For:
Commercial sign installation & maintenance
Construction & steel erection
Utility pole installation & power line work
Tree service & maintenance
Industrial maintenance crews and city service fleets
Crane rental fleets and subcontractors needing boom flexibility
🔍 Condition & Highlights
Year: 2016
Crane Hours: [Insert crane usage if known]
Tires: 70–85% tread, DOT-compliant
Hydraulics: Fully functional, load tested
Title: Clean title, no salvage or damage history
Inspection: Ready for jobsite or fleet use
💰 Pricing, Delivery & Financing
Priced competitively against Altec, Terex, and National Crane alternatives
Financing available (OAC) – flexible terms
Nationwide shipping available – fast and insured
Trade-in and package fleet deals available
🔧 Why Elliott?
Industry leader in high-reach boom trucks – Trusted by sign, utility, and lift operators nationwide
Built in the USA – Superior quality, long service life, excellent support
Durable design + smart controls – Made for daily use on tough jobs
High resale value – Proven brand with strong aftermarket demand
