(Sold) $125,000.00 Terex Schaeffer Heavy Duty Dual DrumCustom-Built Concrete - Rock - Shale - Frozen Ground Grinder
Posted Date: Jul 4th, 2024 at 06:58 AM
Price: $40000.00
$125,000.00 Terex Schaeffer Heavy Duty Dual Drum Custom-Built Grinder
Specifications:
- Price: $40,000.00 (originally $125,000.00, save $85,000.00)
- Condition: Excellent, used on one job before COVID-19
- Applications: Concrete demolition, tunneling, rock profiling, sandstone, shale, frozen ground trenching
- Features:
- Depth protection limiter guard for extremely hard concrete with rebar and hard rock scaling
- Produces 3-4 times more volume per day than a hydraulic breaker
- Lower cost and noise volume
- Produces a finished product ready for use as road base or fill without further processing
- Inclusions:
- Excellent picks (teeth)
- Low-hour unit
- 100 mm front and rear pin bosses
- 14.2 inches between the ears
- Had water misting system installed for dust suppression - just add pressurized water
Compatibility:
- Fits any pin grabbers that take 100 mm front pins with 14.2 inches between the ears
- Can be bushed down to 90 mm to fit any 250-350 class excavator
Specifications:
- Hydraulic input power: 160 HP
- Oil flow rate required: 66 - 106 gpm
- Cutting head width: 47.2 inches
- Weight: Approximately 4530 lbs with pin-on or pin grabber top mount plate with 100 mm pins
- Recommended excavator weight: 66,000 - 100,000 lbs (third member mounting) will work on 240 + Class With Caution
Fields of Application:
- Canal and pipeline construction
- Landscape gardening
- Bioremediation/soil mixture
- Quarrying
- Sensitive areas
- Road construction
- Tunneling and mining
- Building renovation and demolition
Additional Information:
- Terex Schaeffer has been manufacturing cutting-edge machinery for over 40 years.
- The grinder includes various hydraulic motors and cutting heads for optimum adjustment to operating conditions.
- The product range includes seven types of transverse cutting units with hydraulic drive powers of 30 HP to 200 HP.
- Special applications include cutting drums and slot cutting drums in various widths and diameters, drums for cutting tree stumps, and anti-dust systems for indoor operations.
Advantages of Cutting Technology:
- Extremely economical
- Extremely accurate cut
- Low vibration
- Low noise
- Suitable for underwater operations
- Low maintenance
- Suitable for narrow and deep trenches
- Recycling of excavated material
Contact Information:
- Frank: 604-476-7777
Additional Resources: (copy and paste)
https://youtu.be/rSleaL-FoCo
https://youtu.be/BdzFNabFKQ4
We can supply trucking anywhere in North America except Mexico and offer great rates.
4o
