******** SOLD ******* 2023 Mercury 20 HP 4 STROKE EFI 20ELH ELECTRIC START
Posted Date: Nov 1st, 2023 at 06:39 PM
Price: $3000.00
2023 Mercury 20 HP EFI EFI 20ELH Short Shaft Outboard Motor 4 Hours TT
THIS WAS BOUGHT WHEN WE INFACT NEEDED A LONG SHAFT - BUT DEALER WOULD NOT TAKE BACK AS WE PUT 4 HOURS ON IT??
WE PAID OVER $4000.00 PLUS TAXES
TAKE THIS NEW MOTOR FOR $3000.00 AND I WILL THROW IN THE MOTOR STAND WE BUILT
LOCATED OUR WATERFRONT HOME CAMBRIDGE NARROW NB
THIS IS A PRIVATE SALE - SO NO TAXES REQUIRED
HAVE ALL FACTORY MANUALS
PRODUCT DESCRIPTION
The Mercury 20 hp EFI outboard motor model 20ELH is an electric start outboard with a 15 inch short shaft with electric start, and multi function tiller handle.
 This low end torque engine has the power and prop needed to quickly plane your boat.
Known for reliability, and fast acceleration, the 20 HP EFI portable outboard by Mercury is an affordable option especially considering the long list of standard features and the Mercury 3-year warranty. Your online outboard shopping ends here!
20hp HORSEPOWER
 11.0 lb WEIGHT
Shaft Length:    15" (Long)
Starting:    Electric
SKU:    20ELH-24EFI
PRODUCT DESCRIPTION
Fast throttle response and fast acceleration are features designed into the 20 HP EFI Mercury Outboard.
With powerful low end torque and a large displacement your boat planes faster and you get to your destination across the water faster thanks to Mercury engineering.
 At 111 lbs. the Mercury 20 HP EFI model 20MH is your affordable choice in the 20 HP line up with a ELECTRIC start and the 15 inch short shaft.
 The 20MH also includes manual tilt, a heavy duty transom bracket, vibration absorbing mounts and Mercury's multi function tiller.
SPECS
MODEL1A20201LK
MODEL YEAR2023
SKU20MH-24EFI
WEIGHT111.0 lb
MANUFACTURERMercury
COUNTRY OF MANUFACTUREJapan
HORSEPOWER20hp
SHAFT LENGTH15" (Short)
STEERINGTiller
STARTINGELECTRIC
TRIM & TILTManual
FUEL DELIVERYEFI
FUEL TANKExternal
CYLINDER(S)2
DISPLACEMENT333 cc (20.3 cubic inches)
BORE AND STROKE61 mm x 57 mm (2.402 in. x 2.244 in.)
FULL THROTTLE RPM RANGE5400-6100
IGNITION SYSTEMCDI w/electronic spark advance
INDUCTION SCAVENGINGSOHC
VALVES PER CYLINDER2
FUEL TYPE87 octane/up to 10% ethanol
FUEL TANK / FUEL LINE3.2 Gallon/12 Liter
OIL TYPEMercury 4-Stroke Outboard Oil
OIL CAPACITY1 Quart (1000 ml)
LUBRICATIONTrochoid Pump
ALTERNATOROptional 12 amp / 138 watt (Electric)
COOLING SYSTEMWater-cooled with thermostat
SALTWATER RATEDYes
GEAR RATIO2.15
GEAR SHIFTForward-Neutral-Reverse
PROPELLER9.2" Diameter X 9.1" Pitch 3-Blade Aluminum
