( Sold) TEREX WS-120MD 160 HYD HP Dual Drum Grinder (For 30-50 Ton Excavator)
Posted Date: Sep 21st, 2024 at 12:00 PM
Price: $35000.00
Maximize productivity and reduce costs with the high-performance TEREX WS-120MD Grinder:
  • Produces 3-4 times more volume than a hydraulic breaker.
  • Lower noise levels and operating costs.
  • Creates a finished product ready for road base or fill without additional processing.
Watch Performance Videos:
Compatibility
  • Pre-configured for long reach PC450LC-8 Komatsu.
  • Fits any machine with 100 mm pins (14.75 inches between ears) or can be bushed down to 90 mm pins.
  • Compatible Machines:
    • Komatsu: PC 400 - PC450
    • Kobelco: SK450 - SK485
    • Hyundai: R420LC - R450LC-3
    • CAT: 324D, 325D, 330, 330D
  • Fits most 250-450 class machines with Geith couplers (90 - 100 mm pins) or other compatible couplers.
  • The top plate can be modified for any 250 - 500 class excavator.
Additional Features
  • Swivel mount for smaller machines (200-270 ton class) for low-overhead and tunnel work.
  • Swivel mount second stick system included (valued over $170,000) available for $45,000.
  • Pressurized water misting system for effective dust reduction.
Specifications
  • Hydraulic Input Power: 160 HP
  • Oil Flow Rate: 66 - 106 gpm
  • Cutting Head Width: 47.2 inches
  • Weight: Approx. 4,500 lbs (with excavator 100-pin mounting bracket)
  • Recommended Excavator Weight: 66,000 - 100,000 lbs
Fields of Application
  • Canal and pipeline construction
  • Landscaping and gardening
  • Bioremediation/soil mixture
  • Quarrying
  • Sensitive areas
  • Road construction
  • Tunneling and mining
  • Building renovation and demolition
About Terex Cutting Technology
  • Over 40 years of experience in hydraulic transverse cutting technology.
  • Market leaders with seven types of hydraulic-driven cutting units (30 HP to 200 HP).
  • Special solutions for various applications with a global network of distributors.
Terex Advantages
  • Extremely economical
  • High precision cutting
  • Low vibration and noise levels
  • Suitable for underwater operations
  • Low maintenance
  • Ideal for narrow and deep trench work
  • Recycles excavated material
Applications
  • Medium-hard to hard rock and concrete
  • Wear-protected spiral blades reduce pick penetration, vibration, and improve operation smoothness.
Additional Resources
Reason for Sale
  • Relocating from BC to New Brunswick due to traffic and smog in the Fraser Valley.
Rental Potential
  • Estimated rental rate: $400.00+ per hour (mounted on a 250-500 class excavator).
Contact Information
  • Frank: 604-476-7777
  • Quick trucking available at great rates.
