2020 Rockwheel MXR-D30LH Twin Drum 20 - 42 Class Excavator Mixer - Grinder - Brush Fire Prevention
Posted Date: Apr 10th, 2024 at 09:05 AM
Thumb 1 Thumb 2 Thumb 3 Thumb 4 Thumb 5 Thumb 6 Thumb 7 Thumb 8 Thumb 9 Thumb 10 Thumb 11 Thumb 12 Thumb 13 Thumb 14 Thumb 15 Thumb 16 Thumb 17 Thumb 18 Thumb 19
Price: $30000.00
2020 Rock wheel MXR-D30LH Twin Drum 20 42 Ton Class Excavator Mixer  WITH 80mm pin top plate with 12.75 inches between the ears
ALSO PERFECT STUMP GRINDER - BRUSH CUTTER - REMOVES TREES AND MIX AND GRIND BRUSH INTO THE GROUND FOR FIRE PREVENTION WITH THIS CUTTER PICK TEETH SYSTEM AND 150 HYDRAULIC HP HEAD.
EASILY CONVERTED TO ROCK EXCAVATION  - CONCRETE DEMOLITION GRINDER BY CHANGING THE DRUMS TO ROCK PICKS
THESE RENT FOR:
ROCKWHEEL D30 ROTARY RENTAL RATES
Daily $1,300
Weekly $3,900
4 Weeks $11,700
See the Rockwheel Information page - copy and paste this link:
https://alpinecutter.com/en/products/soil-mixers/transverse-mixers.html
SEE THE COMPLETE ROCKZONE WEBSITE FOR ALL APPLICATIONS THIS UNIT CAN DO - (COPY AND PASTE) :
https://rock.zone/en/
OR SEE ALL VIDEOS OF THESE IN ACTION:
https://www.youtube.com/user/ALPINECUTTERS/videos
Soil remediation tools for the treatment of Soil, Sludge, Dredged material, contaminated sites, and oil & gas drilling waste.
Excellent Condition 2020 Unit Ready to Work c/w Pin Grabber Top Plate Mounting System
New Cost $100,000.00 Take It For $30,000.00 BEFORE WE MOVE BACK TO NB
Frank 604-476-7777
MXR-D30LH Specifications:
Input Power hp (kW) 150 (110)
Required Flow Rate GPM (l/min) 55-110 (208-412)
Max Operating Pressure max. psi (bar) 5800 (400)
Drum Speed RPM 75 - 140
Mixing Head Torque (max) ft.lb (Nm) 17,250 (23.4)
Weight (without bracket) lbs (kg) 3600 (1635)
Intended Carrier Size: 25-42 ton
  Mixing blades customized for the job. Affects drum dimensions
• Suitable for wet or dry mixing
• Compatible with pressure feeder systems
•OPTIONS THAT ARE INCLUDED:
   Injection Piping And Spraying Piping
   Extension Brackets
   Extreme Duty Blade Configuration
   Quick Hitch Pin Grabber Mounting Bracket
Optional:
• Long housing offers a deeper depth reach and reduced housing debris obstruction
• Optional depth limiter & collision preventer
Note: Drums can be quickly changed to many drum configuaration see the Rockwheel Brochure (copy and paste)
https://alpinecutter.com/wp-content/uploads/2016/05/ROCKWHEEL-Americas-Workbook-EN_.pdf:
Carriers of any size can utilize alpine’s Twin Drum-series of mixers. From compact minis to 75+ ton excavators, we’ve got you covered regardless of the scale of your task. Durable, robust gearboxes adapted from the mining industry allow these tools to be used in the most severe applications. We offer a variety of drum configurations to mix materials ranging from liquid sludges to firm compact soil. The torque on these units is unmatched and the various motor options within each model allow us to ideally match the soil mixing attachment to your application.
Any of Alpine’s soil mixers can be equipped with injection piping for either dry or wet additives. If your application requires custom depth reach, we design and build custom extension brackets.
 Specifications
Robust enough for the toughest applications, every MXR model has a range of motor configurations that allow
adjustment for site specific conditions and pairing with the hydraulic output of the carrier excavator.
In addition to optimizing drum speed, input power and torque, drums are designed for maximum blending
efficiency and homogenization of the substrate. The dual, discontinuous spiral pattern of mixing blades generates
simultaneous lateral flow and vertical shearing which results in a uniform mix and high surface area contact
between additives and substrate. Custom drum design and build services available.
Intended Carrier Size: 20-42 ton
• Mixing blades customized for job. Affects drum dimensions
Frank 604-476-7777
