NEW $85K KINSHOFFER EXCAVATOR 20K CAPACITY DEMOLITION GRAPPLE OR EXCAVATOR MOUNTED LOGGING 20K CAPACITY GRAPPLE$7500.00 BOLT ON TOP PLATE SYSTEM -
Posted Date: Dec 1st, 2023 at 05:11 PM
Price: $45000.00
EXCAVATOR MOUNTED LOGGING 20K CAPACITY GRAPPLE C/W WITH NEW CUSTOM EXTREME DUTY $7500.00 BOLT ON TOP PLATE SYSTEM - THIS IS NOT A WELD ON SYSTEM BUT CUSTOM ONE WAY BOLT ON SO YOU CAN CHANGE EAR SETS QUICKLY WITH ONLY A MILWAUKEE ELECTRIC IMPACT REQUIRED ON ONE WAY TAPPED EASY ACCESS BOLTS
TAKE THIS 85,000.00 PLUS COST OF TOP PLATE SYSTEM GRAPPLE FOR $45K JUST LOWERED THE PRICES TO MOVE THIS EQUIPMENT QUICKLY - FRANK 604-476-7777 OR TOLL FREE Phone : 1-(833) 693-9323 ONLY SELLING AS LEAVING BC TO MOVE TO OUR NEW HOME IN NB AFTER 53 YEARS IN DEMOLITION - TRUCKING
MODEL T40HPX-114 2 CUBIC YARD 360 DEGREE ROTATION GRAPPLE 19000 LB CAPACITY - BRAND NEW DEMOLITION OR LOGGING GRAPPLE WITH HPX DRIVE NO HYDRAULIC CYLINDER GRAPPLE
CURRENTLY AT DC WELDING WHO IS INSTALLLING A BRAND NEW BOLT ON TOP PLATE WITH 90MM PINS WITH 12.80 INCHES BETWEEN THE EARS TO PUT ON A PC360LC-10 WITH GEITH PIN GRABBER COUPLER - THAT EXCAVATOR IS NOW SOLD.
WE WERE ALSO GOING TO MOUNT ON OUR LONG REACH PC450LC-8 KOMATUD WITH PIN GRABBER MOUNT BY BUILDING ANOTHER 100 MM BOLT ON TOP PLATE
HAS CONSTANT HI-PRESSURE GRABBING FORCES AND DOES NOT RELEASE PRESSURE UNTIL DONE BY THE OPERATOR
THIS USES A HELIX STYLE DRIVE AND INTERNAL ROTATOR - IT HAS A QUICK CHANGE GRAPPLE SYSTEM TO CHANGE TO MULTIPLE CHOICES FOR DIFFERENT GRAPPLE ARMS FROM LOGGING - DEMOLITION - ETC
GRAPPLE NEW IS OVER $85,000.00 PLUS OVERSEAS SHIPPING - CUSTOMS AND 16 WEEKS OF LEAD TIME
TAKE THIS UNIT TODAY SITTING AT DC WELDING IN LANGLEY BC WHO WOULD MODIFY IT TO YOUR NEEDS - IT IS THERE TO INSTALL THE EXCAVATOR TOP PLATE SEEN IN THE 5 PICTURE - IF YOPU WANT IT WITH THAT TOP PLATE INSTALLED - IT WILL BE $45,000.00 - (NOTE: THIS BOLT ON HD TOP PLATE SYSTEM C/W PINS COST ME $7500.00)
PERFECT FOR UNDERWATER WORK, LOGGING OR DEMOLITION AS NEVER EXPOSE HYDRAULIC CYLINDERS WHEN WORKING
TAKE THIS NEW GRAPPLE TODAY FOR $45,000.00 WITH THE NEW BOLT ON TOP PLATE
DC WELDING WOULD BUILD YOUR TOP MOUNTING SYSTEM TO FIT YOUR MACHINE - AS THE BOLT ON BASE PLATE SSYTEM IS ALREADY INSTALLED - THEY DO GREAT EXPERT WORK AT A REALISTIC COST.
ONLY SELLING AS WE ARE RETIRING AND SELLING ALL MY EXCAVATORS AND ATTACHMENTS
WILL SHIP QUICKLY WE GET GREAT RATES AND SERVICE
THIS GRAPPLE WILL PIN ON THE FOLLOWING MACHINES DIRECTLY OR ANY PIN GRABBER THAT TAKES 90 MM PINS WITH 12.80 INCHES ACROSS THE BOTTOM MOUNT
Case CX240 Case CX240 Case CX290 Case CX290
Komatsu PC240 Komatsu PC240 Komatsu PC250-6 Komatsu PC270 Komatsu PC270LC-6 Komatsu PC270LC-7 Komatsu PC280 Komatsu PC280 Komatsu PC290
Link-Belt 240LX Link-Belt 290LX Link-Belt 3400 QUANTUM Link-Belt 3900 QUANTUM
ALL PARTS AND QUICK CHANGE GRAPPLE SHELLS (ARMS) ARE AVAILABLE FROM:
KINSHOFER Canada 5040 Mainway Drive, Unit #11 Burlington, ON, L7L 7G5 Tel.: +1 (905) 335 2856 Fax: +1 (905) 335 4529 Toll Free (North America): 1 (800) 268 9525 Email: [email protected]
KINSHOFER GmbH is a leading manufacturer of attachments for truck cranes and excavators for the most important industries worldwide.
From our headquarters in Holzkirchen, Bavaria, we offer our customers an extensive range of attachments for equipment carriers with or without hydraulics for scrap, demolition, track construction, landscaping, general construction, snow clearing, excavation, road construction, forestry, recycling, etc.
The continuing demand for transportation and infrastructure is constantly driving our product development and the service we offer. As a result, we are continuously expanding our product range in order to develop and produce technical highlights in the industries.
The cylinderless and low-maintenance technologies that are used for the HPXdrive on grapples or the NOX tiltrotators and TC tilt couplers are examples of these innovations, as are the products for special requirements or unusual uses from our special solutions department.
With high quality, variety and the latest technology, KINSHOFER crane and excavator attachments set standards worldwide.
Technologies - HPXdrive Excavator
Functional exchange, depending on demands! During times of growing costs and environmental awareness, efficient working is getting more and more important. The HPXdrive stands out thanks to its extended lifetime compared to a conventional cylinder-driven grab.
Compared to conventional cylinder grabs, the closing force of the HPXdrive is high and constant during the entire operation. The movement of the arms is generated by two hollow shafts, which run opposd and have a helix thread, hydraulically driven by a single piston. The resulting closing force is always the same no matter the position of the shells
Thanks to the shell exchange system you are able to clearly lower the investment costs for your fleet.
Just change fast and easy to the suitable shell option depending on the task. The reliable shell exchange system features an easy loosening of the shells in case of exchange and a safe and steady holding of loads during every task. Setup times can be reduced to a minimum. The flexibility of your work processes as well as your competitive abilities can be increased.
