OKADA OAC200 CASE 480-690 RTLH BACKHOE OR 60-120 CLASS EXCAVATOR PLATE COMPACTOR
Posted Date: Oct 13th, 2024 at 11:13 AM
Price: $4000.00
OKADA OAC200 CASE  RTLH  CLASS PLATE COMPACTOR FOR ANY MODEL CASE 480-690 WITH CASE PIN COUPLER OR ANY MACHINE WITH HYDRAULIC PIN GRABBER COUPLER
CUSTOM BUILT BY OKADA FOR CASE BACKHOES  480B, 480C, 480D, 480E, 580, 580B, 580C, 580D, 580E, 580 SUPER E, 580K, 580 SUPER K, 580L, 580 SUPER L, 580M, 580 Super M, 680, 680B, 680C, 680E, etc.
HAS BOTH 10.5 INCHES AND 14 INCHES CENTER TO CENTER ON PINS WITH 10.25 INCHES BETWEEN THE EARS
LOW HOUR EXCELLENT READY TO WORK OKADA PLATE COMPACTOR
Description
Okada boom mounted plate compactors let you expand the versatility of you backhoe or excavator.  There is a model to perfectly match the capabilities of your carrier.  Rugged construction and proven compaction technology make quick work of any compaction or driving task.  Keep your crew safely out of the trench and eliminate the need for expensive shoring.  The OAC Series line of compactors provides superior power and efficiency, with minimal maintenance to keep you working.
TAKE IT FOR $4000.00   FRANK 604-476-7777
IMPULSE FORCE  6500 FT   LBS
OPERATING WEIGHT 840  LBS
OIL FLOW    GPM  20
OPERATING PRESSURE    PSI   2000 - 2200
BOTTOM PLATE    INCHES 23X34
HEIGHT  INCHES   30
 LIFT COMPACTION    FEET 2-4
CARRIER WEIGHT RANGE  12 - 18 LBS
 The OAC Series line of compactors provide solutions with superior power and efficiency
for all your compaction tasks, and help ensure you meet Proctor soil density requirements.
YOUTUBE VIDEO COPY AND PASTE  https://www.youtube.com/watch?v=WEFTvQJ-d7c&;t=6s
Company;  OKADA AMERICA
Factory or Website Url:  https://okadaamerica.com/
Website To Display Url : https://okadaamerica.com/en/oac200
ALSO HAVE :  CASE 18 INCH BUCKET FITS CASE BACKHOES 480B, 480C, 480D, 480E, 580, 580B, 580C, 580D, 580E, 580 SUPER E, 580K, 580 SUPER K, 580L, 580 SUPER L, 580M, 580 Super M, 680, 680B, 680C, 680E, etc. (Made in USA) FOR $600.00 EACH
