ONE OF A KIND CUSTOM BUILT $1.3 MILLION LONG REACH EXCAVATOR - SHEET PILE DRIVER - DEMOLITION UNIT
Posted Date: Nov 16th, 2023 at 04:39 PM
Price: $400000.00
ONLY MACHINE LIKE IT IN NORTH AMERICA TOOK 2 YEARS TO PUT TOGETHER TOTALLY REBUILT MACHINE FINISHED IN 2023 LOOKS AND OPERATES AS NEW WITH NO EMMISIONS ISSUES
NOR DEF - SENSOR ISSUES
UNIT LOCATED IN NAHANNI TRUCK AND TRAILER LANGLEY BC YARD - HAVE A TRUCKER THAT WILL MOVE THIS MACHINE QUICKLY IN ONE PIECE ANYWHERE IN CANADA - HAVE THIS READY TO WORK MACHINE ON THE JOB AND READY TO WORK NOW - - NOT LIKE CRANES *** FINANCING AVAILABLE O.A.C ***
THIS IS NOT A SPAGETTI BOOM LONG REACH - USE LARGE 12000 ft lb HYDRAULIC HAMMERS - 10,000 LB HYDRAULIC DEMOLITION PROCESSORS - GRAPPLES - HYDRAULIC DUAL DRUM GRINDERS - PLATE COMPACTORS - DIG WITH VARIOUS BUCKETS UP TO 4 YARDS ALL WITH ONE MACHINE
HYDRAULIC REMOVEABLE KOMATSU DEMOLITION COUNTERWEIGHT ($50,000.00 Factory Option) PLUS $35,000.00 IN ADDITIONAL CUSTOM REAR TOP MOUNTED WEIGHTS THAT IS DESIGNED TO GO AROUND THE FACTORY HYDRAULIC DROP SYSTEM - KEEPS REAR SWING CLEARANCE TO FACTORY SPECS OF 1.320 METERS OR 52 INCHES SO AS TO SWING OVER SHEET PILES WITH A 42 INCH WCB REQUIRED ABOVE GROUND HEIGHT WHILE DOING THE EXCAVATION SWINGING OVER THE SHEET PILES
CAN BE MOVED COMPLETE ON 8 or 9 AXLE LOW BED AT HEIGHT OF 14 FEET ON THE BED
CHARLIE SMITH MACHINE REMOVED THE EXISTING EXCAVATOR BOOM AND INSTALLED A BRAND NEW KOMATSU LOG LOADER BOOM C/W NEW HYDRAULIC CYLINDERS - REMOVED THE GRAPPLE AND CUSTOM INSTALLED THE ORIGINAL STICK - REBUSHED THE ENTIRE STICK COMPLETELY REBUILT BOTH BUCKET - STICK CYLINDERS - REBUILT THE GEITH HYDRAULIC PIN GRABBER COUPLER
DC WELDING LANGLEY INSTALLED ADDITIONAL CUSTOM QUICK DETACH COUNTERWEIGHT'S THAT FIT BEHIND AND CAN BE REMOVED WITH THE FACTORY HYDRAULIC DROP COUNTERWEIGHT A COST OF OVER $35,000.00
MACHINE HAS 0 WORKING HOURS ON NEW FACTORY KOMATSU HYDRAULIC PUMPS INSTALLED
SMS KOMATSU SURREY WENT THROUGH AND REBUILT THE COMPLETE HYDRAULIC SYSTEM INCLUDING THE MAIN VALVE BODY TO INSTALL THE ADDITIONAL HYDRAULIC VALVES AND SET UP TO RUN THE NEW HYDRARAM SHEET PILE DRIVER OR ANY DEMOLTION ATTACHMENTS FOR A COST OF OVER $75,000.00
NAHANNI TRUCK AND TRAILER BLASTED THE UNDERCARRIAGE AND ALL GUARDING WAS REMOVED AND BLASTED AND MAIN BODY WAS HAND SANDED THEN COMPLETELY PAINTED WITH QUALITY EPOXY PAINT AND NEW KOMATSU DECALS INSTALLED ON THE MACHINE
SET UP FOR DEMOLITION PROCESSORS - HAMMERS - GRAPPLES - LARGE HOE-PAKS - DUAL DRUM GRINDERS - VARIOUS DIGGING BUCKETS ETC.
ALL OF WHICH ARE AVAILABLE FOR THIS MACHINE TO WORK NOW - SEE MY OTHER ADS.
MACHINE COST TO REPLACE WELL OVER 1.3 MILLION AND WITH TODAY'S ISSUES MORE THAN 6 - 12 MONTHS OF PARTS AND WORK. TO BUILD
NOTE: THE APPRAISAL OF THE MACHINE SHOWN WAS DONE BEFORE MACHINE WAS FINISHED AND BEFORE I SPENT ANOTHER $300,000.00 PLUS ON COMPLETION - MACHINE IS CLEAR TITLE - READY TO WORK - NEEDS NOTHING
SEE COMPLETE DETAILS AND 130 PICTURES OF THIS MACHINE HERE: (copy and paste web link)
https://www.mediafire.com/folder/5j7f20t4zrld4/K%20OMATSU-PC450LC-8
Excavator Details
This unique excavator is a game-changer, designed to handle a range of tasks with precision.
A comprehensive rebuild was executed, sparing no expense, resulting in a fully enhanced machine finished in 2023.
Note: Replacement Cost Well over $1,300,000 without the HydraRam Sheet Pile Driver
Features:
Excavator Hours: 7,300 (Total Rebuild in 2023)
Custom All Komatsu 3-Piece Boom for Multiple Versatile Attachments
Enhanced for Sheet Pile Driving, Excavation, Demolition, and More
Comes with New 2021 175 Hydraulic HP HydraRam Sheet Pile Driver (Value: $250,000) for $500,000
Our Total Investment: Over $600,000 or $800,000 with HydraRam Sheet Pile Driver
As New Hensley 46-Inch Extreme-Duty Digging Bucket Included
Capabilities:
Excavating To 34-36 Feet Depth with Included 46 Inch 2.5 Yard Bucket - 70 Inch 4 Yard Bucket Available (Both are Hensley Extreme Duty)
Sheet Pile Driving
Large Hydraulic Hammers and Demolition Processors Hydraulic Grapples - Demolition (Vertical and Horizontal Reach: 60-70 Feet Depending on Attachment)
Large Dual Drum Grinder
Additional Equipment Available:
Kishoffer T40HPX – 114 Helix Drive Grapple with 20,000 lb 2.5 Yard Capacity (Value: $85,000)
Choice of Several Buckets
Okada Cut82 Rotating Demolition Shear
2020 - 0 Hours Since Factory Rebuilt Okada Model: ORV7500 7500 ft lb hammer Serial Number: 363B538 Dimensions: 124" L Operating Weight: 5,950 lbs
…and much more!
Why Choose This Excavator:
Handles Various Attachments with Ease
Custom 3-Piece Boom for Precise Operations
Rebuilt and Enhanced for Exceptional Performance
Can Replace Cranes for Sheet Pile Work in Tight Locations
Versatile and Productive Addition to Any Fleet
Will Look At 35-40 Foot Newer Class A Diesel Pusher Motorhome Or A 1964 - 1971 Classic Muscle Car As Part Trade
Financing Available OAC
Contact Frank: 604-476-7777
FROM THE HYDRARAM WEBSITE:
Hydraram, we bring the muscle!
Hydraram has been producing attachments for use in demolition, recycling and green industry for over 25 years.
We supply a complete line of hydraulic attachments for excavators from 1 to 300 tons.
We specialize in all hydraulic attachments for all types of excavators.
The Hydraram products stand for quality, durability and productivity! Hydraram attachments are used around the world every day by many international companies in the the civil engineering sector, demolition, scrap processing, as well as recycling and forestry companies.
We sell our equipment through an extensive dealer network which provides perfect service. Because of this, we are able to help you choose the right attachment, and receive perfect after-sales support, maintenance and repairs.
With us you are at the right place for:
* New attachments
* Used attachments
* Rental (by HYDRARENT)
* Service & maintenance
* Repairs
* New & used parts
We always have the correct type of attachment. They are of high quality, durable, and always made to match your needs and requirements. Keeping attachments in stock helps us keep shipping times as short as possible.
NOTE: The Appraisal Shown in image #6 does not take into account the cost of the New $150,000.00 Factory Komatsu Log Loader Boom c/w pins and cylinders or the $200,000.00 plus spent after this viewing to complete the machine to its current finished state.
Note: Due to health reasons - (THE FOG IN GHT FRASER VALLEY - THE TRAFFIC IN THE FRASER VALLEY, after 53 years in the demolition and rock excavation business we’re retiring and relocating, which is why we’re selling this exceptional piece of equipment.
